    šŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Modelovanie
    3 Posts 3 Posters 1.7k Views 3 Watching
      pallok
      Ahojte vÅ”etci, chcem sa spýtaÅ„, ako priradiÅ„ prvku vlastnosti zrkadla? Ďakujem pekne
      Hi everyone, I want to ask how to assign the element properties mirror? Thank you very much
        davidheim1
        I think you are referring to the Flip Along command. Select the geometry or component you wish to mirror, then copy it and move the copy slightly away from the original. Select the copy and go to the Edit menu; select either Entity or Solid Component then choose Flip Along. You can flip the copy along the red, green, or blue axis.
        I hope this helps.
        David
        • daleD Offline
          dale
          The Scale tool can also be used to mirror geometry by pulling the middle grip in the centre of the object towards and then beyond the point about which you are scaling. This operation allows you to pull geometry inside out. You can achieve the mirror by typing in a -1 value in the status bar dimension box on the bottom right of the window, after beginning to pull the grips to scale the object.
          Here is a link to a YouTube tutorial.
          Cheers
