    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Rounding
    6 Posts 4 Posters 2.2k Views 4 Watching
      morci429
      Hi everyone,
      As you all know i'm knew to Sketchup ruby and i can't find this anywhere online.
      I have a variable that has a float number and i wanted to round it.
      Var = 1.8854523497846
      Desired answer Var = 1.9
      Also if i can recommend any online sources for Sketchup ruby Iโ€™ll be thankful
      • Didier BurD Offline
        Didier Bur
        Caution: this will create a constant (not very suitable for a variable)
        var = 1.8854523497846
        is better ๐Ÿ˜‰
        a.floor # returns 1
        a.ceil #returns 2
        a.round #returns 2
        a.round(1) #should return 1.9, but appears not to work as expected
        SU uses Ruby 1.8.6 and .round(x) is new in Ruby 1.9. You'll have to wait for SU9 or code it yourself, or like this:
        def prec(x)
        		a=self.to_s.split(".")
        		if not a[1]
        			return self
        		if a[1].length > x-1
        			return(a[0] + "." + a[1][0..(x-1)]).to_f
        		else
        			dif=x-a[1].length
        			return(a[0] + "." + a[1] + ("0"*dif)).to_f
        var.prec(6) #returns 1.885452
        ๐ŸŽ‰
        See http://www.ruby-doc.org/core/ and select the 'Float' class.
        For online SketchUp-Ruby docs, see: http://forums.sketchucation.com/viewtopic.php?f=180&t=10142 (well done Dan !)
        Hope this helps,
        DB
        • Dan RathbunD Offline
          Dan Rathbun
          @morci429: In reality.. there is no such think as "Sketchup Ruby." There is only Ruby, that that gets loaded by the Sketchup application, and then loads special Google API modules and classes, that extend Ruby so we can work with SKP models.
          You need to learn Standard Ruby.. first. And you must have the Reference for the Standard Ruby Modules and Classes.
          @didier bur said:
          I suppose SU uses an older version of standard Ruby ?
          Yes, you poined to the current Ruby 1.9.x core.
          I have links to the online 1.8.6 and 1.8.7 Core Refs, as well as downloadable offline CHM Refs in this post:
          [url=http://forums.sketchucation.com/viewtopic.php?f=180&t=10142#p266725:1bdc3prs]RUBY PROGRAMMING REFERENCES[/url:1bdc3prs]
          I'm not here much anymore.
            Dan Rathbun
            How about:
            var1 = ((var*10.0).round)/10.0
            OR for a singleton Mixin method, save as 'mixin/float_round_to.rb'
            (make a subfolder under plugins called 'mixin' and put the file there.):
            module Mixin; end
            module Mixin;;Round_to
              def round_to(num)
                places = 10.0**num
                return ((self.to_f*places).round)/places
            end #module
            then use it by extending your variable:
            require('mixin/float_round_to.rb') var.extend(Mixin::Round_to) var1 = var.round_to(1)
            1.9
            var3 = var.round_to(3)
            1.885
            var8=var.round_to(8)
            1.88545235
              morci429
              Many thank everyone
              Dan Rathbun you are a genies
                If you want to round it as output [as astring] then you can use
                var_string = sprintf("%.1f", var)
                for 1 dp etc
