    Dynamic component and curved path
    Scheduled Pinned Locked Moved Dynamic Components
    20 Posts 4 Posters 4.0k Views 4 Watching
    • V Offline
      Valent1G
      Hello!
      I would like to create a dynamic component that duplicates itself along a path, which is moving according to the normal path.
      I saw that the plugin modelfunction can do it, but is it possible with the dynamic components?
      My goal is to place the seats in a theater, and the bleachers are curved ...
      Thank you for your attention,
      Valentin
        Hi Valentin and welcome!
        I know little about dynamic components but we have a dedicated subforum (under the main SU discussions) where I have now moved your post.
        • jason_marantoJ Offline
          jason_maranto
          If this is possible it will most likely be through the use of trig functions -- I have not tried it myself but check these out for some ideas:
          http://forums.sketchucation.com/viewtopic.php?p=109276#p109276
          Best,
          Jason.
          • V Offline
            Valent1G
            Hello!
            Sorry Gaeius, I didn't see the subforum... Thank you for putting the post in the right section! ^^
            I progress in the reflexion, and I have found the equation for spreading the seats along an arc : it works on excel for the moment. I use the parametric equation of a circle which is :
            x=a+r.cos(O)
            y=b+r.sin(O)
            It is always a little bit hard in a linear system because I have to set the spacing between the seat and the armrest. I am not so far from the solution I think...
            I'll keep you updated on the progress!
              No problem at all - indeed it is not displayed on the forum index (our bad, I know). I hope you get better support here.
              • V Offline
                Valent1G
                New problem!
                I want the spacing between my seats that are duplicated either variable for my dynamic component takes exactly the length I want. I do not want it shrinks or grows ...
                My approach for now is to give the user the opportunity to enter a minimum spacing between seats, and then the modulo copy number is distributed between the seats created ... However, the component does not always take the exact value that I ask ...
                Does someone have any ideas?
                Thank you!
                Valentin
                  jason_maranto
                  It would be easier to help if we could see where you are with the actual DC.
                  Best,
                  Jason.
                  • V Offline
                    Valent1G
                    That's right! 😳
                    Here is my file : Seats.skp
                    The problem is that the DC doesn't take the right lenght, and when there is few seats, spacing is too big... and it really doesn't work with one seat!
                      jason_maranto
                      Before I get too much into the DC functions I will say you can save quite alot of files size here by going to the components dialog and using the fly-out menu command "purge unused" and then do the same in the material dialog... this will drop the file size considerably and save alot of bandwidth. πŸ˜‰
                      Best,
                      Jason.
                        jason_maranto
                        Is there a reason you want the seats to be separate from the arms? The reason I ask is this would be much more straight forward if they were all one component and under one set of calculations.
                        Best,
                        Jason.
                        • V Offline
                          Valent1G
                          Thank you for the tip of the size! ^^
                          Yes, it is necessary to separate the arms from the seats. The arms have to be exactly in the middle of 2 seats... I know it do a lot of computation, but I can't do otherwise...
                            jason_maranto
                            I had to clean this up a bit, hopefully it is what you were looking for... I tried to make the naming make sense so you could follow the logic of the changes -- this was done through a combination of changing the axes position for each component and placing the grey arms within the repeated seat as a child.
                            Everything is based on the placement aid component so if you do not want to see it you should hide it, but not delete it.
                            Best,
                            Jason.
                            Seats_mods.skp
                            • V Offline
                              Valent1G
                              Yes, this is what I did at the beginning. But in fact, the logic of the spacing is
                              "seat - spacing - seat - spacing - seat - etc."
                              and not "seat - spacing - arm - spacing - seat - spacing - arm - spacing - seat - etc.".
                              The length Y of the arm don't have to be count in the total lenght of the main component.
                              The other problem is when I want a length equivalent to 4.5 seats for instance. SU shrinks to 4 seats or grows to 5 seats. But how can I have a lenght of 4.5 seats, with 4 seats, and the 0.5 seats remaining distributed in the spacing between the seats?
                              I think your idea of using the aid to positioning is very good. I will think with this!
                              Best,
                              Valentin
                                jason_maranto
                                I think I understand better what you are aiming for now -- you want to take the "extra" space the user has defined and use it to "fill-in" an equal amount of spacing between each chair... and that could be any number and the user defined amount is simply a minimum?
                                If that the case an extra custom attribute called "extra_spacing" could be an equation that looked like this:
                                = ((Total width-(copies* initial_spacing))/copies)+initial_spacing
                                take that number and use it for the actual spacing of the copies.
                                Would that work for your needs? I'll try it when I get to the studio.
                                I'll say right up front you might find it better to set up the total length as a numerical value input via the user (via component options) rather than trying to use the scale tool.
                                Best,
                                Jason.
                                • V Offline
                                  Valent1G
                                  Yes! That sounds pretty good!!! The value enter by the user is effectively a minimum...
                                  I will try it tomorrow! I hope it will work.
                                  Thanks a lot!
                                    jason_maranto
                                    Here's a version that works (I think) the way you want it -- I had to stick a few logic functions in there and a maximum value the user can input (just like the minimum value)... which was an attempt to keep the weirdness at bay when you get down to 1 or 2 chairs (to that end it was only partially successful).
                                    But it does scale nicely with the arms spaced evenly and if you change the minimum value is adjusts accordingly.
                                    I also spread out some of the equations to make it easier to read and change (if need be).
                                    I'm sure it could be made better, if somebody else wants to jump in as well.
                                    Hopefully this helps.
                                    Best,
                                    Jason.
                                    Seats_mods2.skp
                                    • V Offline
                                      Valent1G
                                      Hi!
                                      I've just found the solution to my problem! Still in a linear system, but it works perfectly!
                                      In fact, users edit the number of seat (it is simplier), and the distance to the bench. All is put just with divisions of the total length of th DC.
                                      I have to try it on a curved path now!
                                      Thanks a lot!
                                      Best,
                                      Valentin
                                      Seats_mods3.skp
                                        jason_maranto
                                        Your newest one doesn't work quite the way I though it should on my machine but if it's what you wanted then I'm very happy for you πŸ˜„
                                        Best,
                                        Jason.
                                          shneidor
                                          I have done it with my new ModelFunction 2.0 that plan to be released very soon. The new version keeps the design in a component quite similare to the SU dynamic component and includes some other improves.
                                          Attached file and video capture
                                          [flash=540,360:tqny54kg]http://www.youtube.com/v/oi_NNOGIZVk[/flash:tqny54kg].
                                          chairs.skp
                                          • V Offline
                                            Valent1G
                                            Thank you for your contribution! It is interresting to see several methods to do that! πŸ˜‰
                                            I had seen this tools, but I thought it wasn't as flexible as you present in your video πŸ˜„
                                            It is really interesting for curve path! I don't succed for the moment with DC...
                                            Nevertheless, I wonder if spacing between seats is adjustable?
                                            Thank's a lot!
