    A Day at the Museum (Natural History Museum - London)
    28 Posts 15 Posters 4.4k Views 15 Watching
    • FletchF Offline
      Fletch
      😳 Thanks Karina.
      Well, this building is actually not originally modelled in SU, it was modelled in Blender and painstakingly converted into a "component-driven" SketchUp model - mostly because it had many reversed face issues due to the conversion process from Blender file to .obj format.
      Also, it's not actually that accurate of a model, in the sense that the real museum is so mind-blowingly complex. It has hundreds of fine terra cotta details including monkeys and birds, etc. Check the link at the beginning of this thread to find out more.
      I hope to visit the building one day. I unfortunately missed it on my last trip to London.
      The brick walls and diamond detail columns are a rough approximate of the "real thing".
      Fletch
        Speaker
        why do I see bar panorama when I click on the image? 😄
        edit: works OK now
        http://www.youtube.com/user/latvietis1234
        • simon le bonS Offline
          simon le bon
          @fletch said:
          Couldn't resist just one more.
          This one is probably my preferred 👍 👍 ☀
          http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/thSue02-post-LG.jpg
          It is a pleasure to see "the master in action" (Don't hesitate to give some more 😄 )
          Re: at a first glance, the panorama won't work for me 😕
          ++Simon
          • N Offline
            notareal
            ++Simon
            Did first end in some pub 😕 But now it appears to work... some what wavy lines. Maybe some conversion problem?
            • FletchF Offline
              Fletch
              Please click the little thumbnail images, not the screenshot! That should work. If not, you need to update your flash player in your web browser, or allow some of the scripts on pan0.net in your browser security settings.
              Just added a different panoramic view today... (slightly lower resolution)
              http://pan0.net/data/users/panos/thumbnails/759/1523.jpg
              Visit the first panoramic here:
              http://pan0.net/data/users/panos/thumbnails/759/1516.jpg
              Oh! the panoramic image of the Bar - that's the site's testpanoramic. If you see it fine, just click the "skip" button you should be able to see the image.
              Fletch
                KarinaGM
                Fletch, what do you use to make those panoramas?
                Do you render as panorama or do you use some software to make the conversion?
                And once it is done where do you make it interactive? in the pan0.net page?
                I've always wanted to prove something like that but I don't know how
                **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                -Benjamín Franklin.**
                • artysmediaA Offline
                  artysmedia
                  very impressive panoramic! 👍 👍
                  Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                  Blog: Artysmedia
                    d12dozr
                    Karina, the spherical image is made in Twilight, and is made interactive in pan0.net. Full instructions here: http://twilightrender.com/phpBB3/viewtopic.php?f=16&t=2322
                    http://goo.gl/f7ooYh
                      simon le bon
                      This time that works,
                      Very Nice 👍 👍
                      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/Sue02-post-LG_Pano.jpg
                      1. Set Camera type to Spherical
                        I haven't found such a choice in Thea. What is the focal length for a Spherical image? In Thea we can go to 1mm!!
                      ++simon
                        Simon, if you don't mind, I split the posts about the Thea panoramas off. You can find the new topic here:
                        http://forums.sketchucation.com/viewtopic.php?f=80&t=34350
                        • 2 / 2
