    Stretch inserted content to cover entire document?
    layout
    2 Posts 2 Posters 986 Views 2 Watching
      davesec
      hi!
      if i make an a2 document (for example) and insert a sketchup model, is there an easy way to stretch this so it fills up the entire document, with no margins? i'm finding by manually dragging the insert it leaves a small margin on either side and can be kind of tricky/laborous to stretch it from corner to corner.
      basically on some of my boards i would like to have a background image covering everything!
        jhauswirth
        Try-
        File->Document Setup...->Grid
        Uncheck Clip grid to page margins
        Turn on Grid display
        Make sure grid snap is on
        You should now be able to resize and snap to the page corners
