    [Request] SU 6,7 & 8 : Version & Build & MR numbers
    13 Posts 5 Posters 2.3k Views 5 Watching
    • Dan RathbunD
      Dan Rathbun
      At one time here or in the old Google forum, someone posted a list.
      I am most in need of the ver 6 numbers.
      I need MIN and MAX build numbers for each MR release, in each minor release, for each major version 6 - 8, so I can build a Hash for community use.
      The API release notes page only gives the latest and omits a few under v7, and most all under v6.
      I'm not here much anymore.
      • K
        kyyu
        There are a few version numbers listed here:
        http://www.filehippo.com/download_google_sketchup/
        • GaieusG
          My version 6 is 6.4.112 (Windows) I believe I did not install the very latest update.
          • Dan RathbunD
            Dan Rathbun
            So you think it may be M5 ??
            • GaieusG
              I thinkDan but I am not sure.
              • Dan RathbunD
                Dan Rathbun
                I got this so far:
                Switched to using a Spreadsheet: need help (a lot of blank build numbers!)
                MS Office Excel
                OpenOffice Spreadsheet (remove .txt to use)
                ver/MR	PC - en	  Mac - en  max - PC  max - Mac   Released
                8.0 M1	8.0.4811  8.0.4810                       2011-01-12
                8.0 M0	8.0.3117  8.0.3161
                7.1 M2	7.1.6860  7.1.6859
                7.1 M1	7.1.6087  7.1.6086
                7.1 M0	7.1.4871  7.1.4870
                7.0 M1	7.0.10247 7.0.10246
                7.0 M0	7.0.8657  7.0.8656
                6.4 M6   6.4.265   6.4.263
                6.4 M5
                6.4 M4
                6.4 M3
                6.4 M2
                6.4 M1
                6.4 M0
                6.0      6.0.1099
                         6.0.515
                         6.0.312
                         6.0.277
                5.0      5.0.305            beta?
                         5.0.295            beta?
                         5.0.260   5.0.262
                old version/build #s can be listed in Registry subkeys under:
                HKCU\Software\BugSplat\
                • Dan RathbunD
                  Dan Rathbun
                  Bump!
                  **Switched to using a Spreadsheet
                  ... need help (a lot of blank build numbers!)**
                  get spreadsheets in 2nd post
                    driven
                    I've got,
                    SketchUp 7 (7.1.6859) Mac free
                    SketchUp 6.0 (6.4.245) Mac Pro
                    SketchUp 5 (5.0.262) Mac Pro trial... Unused...... does that make it collectable???
                    I've got others on other computers as well, I'll have a look and try and find the other numbers.
                    good luck
                    • KrisidiousK
                      Krisidious
                      my versions installed currently
                      SketchUp 5 ver 5.0.260
                      SketchUp 6 ver 6.4.112
                      SketchUp 7 ver 7.1.6860
                      SketchUp 8 ver 8.0.4811
                      By: Kristoff Rand
                      • Dan RathbunD
                        Dan Rathbun
                        Thanks guys.
                        The challenge here is to match version/build numbers with MR numbers and localizations.
                        I image both John and Kris are using en-US localized builds.
                        John, your 6.4.245 cannot be 6.4 M6 (the latest security release,) so do you think it is probably 6.4 M5 ??
                        Kris, if the assumption for John's version is true... your 6.4.112 cannot be M5 or M6.
                        What MR release do you think it could be?
                        When it comes to MR nums for branches 5.0 and 6.0, I have no idea how many MRs there were (for each including M0,) or what the initial build for M0 was, or the last build was for the final MR.
                        It would be nice to allow a script to identify MR numbers for these branches, but the Google guys want us to forget about them. (Each week people download and install some of these older obsolete versions, from 3rd party download websites. But I assume the Google Updater will notify them that a newer version is available... and they are led to the Google download page, where it's hoped they will install ver 6.4 at a minimum.)
                        • KrisidiousK
                          Krisidious
                          mine is En Version but I don't know what MR's are... so I would need more explanation of where I can get the info on each install.
                          By: Kristoff Rand
                          • Dan RathbunD
                            Dan Rathbun
                            THAT IS the problem I am trying to solve... only Google has the answers, because the MR (Maintenance Release,) number is:
                            • not part of the Installer binary filename* is not a property saved with the Installer binary* is not a property saved with the sketchup program binary* is not a part of the Sketchup version number* is not exposed thru the API as a method or constant.
                            I tried my darndest to get them to do this for the SU 8 releases, but they wouldn't citing "internal complex reasons."
                            So I am endevouring to write a script that will set a Ruby constant for the MR number when Sketchup loads. (I have it proto'd out just need to plug in the build number in the correct places in the script.)
                            • Dan RathbunD
                              Dan Rathbun
                              So I'm hoping someone out there does what I do when I download an Installer for a new Maintenance Release.
                              I make folders (on my E:\ drive,) and name them MR0, MR1, MR2 ..etc., and save the Installers there in the folder for the matching MR.
