    [REQ]Automatic replace components randomly
    12 Posts 5 Posters 2.8k Views 5 Watching
      If not yet exist 😒 (minor and MAJOR request 😄
      Minor request:(construction of a 24 Components positions of a quadrangular volume given)
      say a dice 😄 ("quadrugular box" can be any volume!)
      but the "envelopping box" gives 24 positions)
      so have a familly of 24 components (can be made manually but with efforts) 😄
      Major request : Replace a selection given of existing components with these 24 randomly (or not = same order) familly above : here dices
      (or better any familly of components so more than 24 😉
      here for example 9 components results
      (if components selected are cubes)
      existing can be this for example and must be replace by the familly dicesdice3.jpg
      and a result can be for example (depending of the origine of dices and components)
      Objective is of course to make modular big forms from ingenious variation of little different volumes from simple volumes 😉dice5.jpg
        Little up ☀
        it's a sort of inverse of the GhostComp from Fredo6
        (replace something complex by something simple)
        http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=8be45af3fda989654bcdf80ca743fc52&filename=replace.jpg
        Here it's more like Replace something simple by a complex one 😄
        Uses are infinite 😄
        More easy : replace selected components by other components from a list of components (randomly in option)
        • simon le bonS Offline
          simon le bon
          Hi Pilou 😉
          Your request is a bit cryptic for me: do you have some other ideas to show? At a first interpretation I think you're requesting a new tool to populate a space.
          (Concerning me, I would like to see these possibilities available into Component Stringer)
          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clf_CompString_035th.jpg
          Some Population Tools:
          Didier Bur [PLUGIN] Compo Spray 1.4.1 Updated 08 January 2011
          Octavian 'TBD' Chis Drop v.1.500
          Octavian 'TBD' Chis Randor v.1.000 ($3.00)
          a4chitect [Plugin] WIP: SmartDrop ruby
          TIG [Plugin] MatrixProximity Update v1.7
          Chris Fullmer [Plugin] Components onto Faces v1.0
          Chris Fullmer [Plugin] Repeat Copy($8.00)
          PS: send me other tools you know, I shall add them to this list 😉
          simon.
            simon le bon
            Now that's clear 😎
            😉 *s
            • Didier BurD Offline
              Didier Bur
              Excusez-moi mais je comprend que dalle
              DB
                @Didier
                Ah fichtre 😆
                C'est pourtant simple 😄
                Imaginons que j'ai une ligne droite de 13 objets : disons des cubes)
                Que j'ai 24 objets (qui sont l'ensemble des positions possible d'un dé dans l'espace posé sur un plan vu de face sans rotation)
                Je dois remplacer chaque cube par un dé pris au hasard dans le corpus des 24 objets!
                (cela serait exactement la même chose si j'avais une ligne de 13 fruits & légumes
                je devrais remplacer chaque fruit et légume par un dé pris au hasard ! )
                Ou comment remplacer des objets sélectionnés cubiques par une famille d'objets (des personnages vivants) pris au hasard 😄
                (hasard que l'on peut définir avec remise ou pas de l'objet tiré,
                ou que l'on prend l'un après dans un ordre donné)
                On peut appeler cela une "instanciation aléatoire"
                Est-ce plus clair? 😄
                Un "copy / Paste in place" aléatoire 😄
                C'est ce que montrait ma dernière image :
                comment remplacer 5 objets sélectionnés par un corpus donné!
                Plus simple encore et plus parlant j'espère 😉
                Remplir des places de parking (objets) avec un corpus de voitures Renault, Peugeot, Citröen toutes cylindrées:)
                Je ne vois rien de bien compliqué dans l'énoncé du problème 😄
                Pour le plugin ça c'est peut-être plus compliqué ou trivial, je ne sais 😄
                Il vaut mieux que les objets soient des "composants" évidemment 😒
                  is that more clear? 😉
                  Different result following family used with 5 any objects select! (here boxes)
                  • N Offline
                    numerobis
                    +1 😄
                    it would be great to have a plugin that can randomly replace selected components with other different components.
                    • srxS Offline
                      srx
                      +1 Good idea. 👍
                      Its like CF "Extrapolate colors", but for components - "Extrapolate components"
                      www.saurus.rs
                        Just a little teaser 😎
                        A cool guy has made the impossible! 😉
                        I believe that he will publish soon his plug! ☀
                        It works like a charm! 👍
                        Here only with a familly of 4 positions / no limited 😉
                        You call the plug and the sculpture change in a second ! 😎
                        My speedy module for test for give you some ideas 😉
                        Dice2.skp
                          Yep the plug is released! 😎
                          Random Replacement of Components by Sdmitch 👍
                          About the 24 positions of the first post 🤓
                          By hand the 24 positions of a simple cube (easy) as Target!!!
                          (I export of course the 24 cubes positions for another futur one)
                          then 24 copy past of one Object component in the same position that you take as Source! (easy) 😄
                          Then launch your plug!
                          Et voilà!
                          I can use now the result (with rename each) for a normal use for my filling space of non periodic volumes 😎
                            Little teaser
                            the 24 positions plug from the first post is made!
                            Just a little option to add and it will be released! 😉
                            A very pleasant plug! Always by Sdmitch 😎
