    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Dual screens
    12 Posts 5 Posters 679 Views 5 Watching
      deanlegg
      Hi All
      I've just upgraded my system , Dell studio 8100 windows 7, i7cpu 870@2.93ghz, 6gb, 64 bit,
      nvidia gts 250 1g, 2 samsung 27" HDTV's,
      Everything seemed ok until I started on larger drawings, when I would get bugsplats, freeze up,SU not responding, and even doing simple things like drawing a line would take a few seconds
      My old system never had these problems and so are a bit confused why the new one has
      What do you think ? The video card maybe, I'm running both screens off the one card
      Please let me know your thoughts
      Cheers Dean
      • KrisidiousK Offline
        Krisidious
        sounds like a script is in wrong to me... are you seeing any video errors? like visual or error codes?
        I was up till recently using 1 GTS 250 1 Gig card to run 3 19" monitors and a 42" HDTV no issues at all... but now I'm running two GTS 250 1 Gig cards.
        I would suggest installing a base blank google install and checking it.
        By: Kristoff Rand
          deanlegg
          Kris
          Could you please explain that a bit more
          What do you mean about a script problem and a blank google
          Thanks Dean
          • AnssiA Offline
            Anssi
            A couple of suggestions
            • upgrade your graphics card driver, if you have not already done so
            • do not use any other system (such as the Nvidia NView) than the basic Windows one to manage your screens and desktop.
            Anssi
              Krisidious
              what I mean is do a fresh install of SketchUp... and like Anssi said a up to date driver is paramount.
              By: Kristoff Rand
                deanlegg
                Thanks guys
                I'll do what you suggest and let you know what happens
                Cheers dean
                  deanlegg
                  Well i did both things and it still happens
                  I moved a simple shape and splat, and then when on the web some pictures were flickering
                  When in SU guide lines appear in infinity making it appear a shape is not filled in, and when you zoom into a guide line to pick the end it dissappears, very odd
                  One correction the card is a GTS 240 1gb
                    Krisidious
                    are you having any issues with any other 3D intensive program?
                    By: Kristoff Rand
                      deanlegg
                      I've just downloaded podium 'I know not 3d' and so far all ok
                      Today I had no splats , but was only using small files
                      I'll keep you posted
                        dsarchs
                        I'd try to start eliminating what causes the errors.
                        Turn off 'hardware acceleration' and see if that fixes it -- if it does it's likely the video card to blame.
                        If not try disconnecting the second monitor (hardware acc. can be back on if the first test founf the gpu to not be the problem).
                        After that ?
                        Knowledge is a polite word for dead but not buried imagination.
                        -e.e.cummings
                          deanlegg
                          I turned the accelerater off and still the same
                          Would running each monitor on its own card help?
                          I think another GTS 240 is about $100, or go for another card?
                          Cheers
                          • Bob JamesB Offline
                            Bob James
                            I reinstalled the keepers and I am back in business.
                            I did the same and life became a whole lot better ๐Ÿ‘
                            Now I do a test after I add any new ruby to see if my (or new) gremlins come back.
