    Taskmatch toolbar plugin??
    5 Posts 4 Posters 533 Views 4 Watching
      jsl
      Was wondering if a plugin was available which enabled easy change from one set of pre-positioned toolbars to another, depending upon the task at hand. Any info appreciated.
      JSL
      • mitcorbM Offline
        mitcorb
        Though I don't normally (or abnormally) do this, I have seen in some video clips for various posts where the author will pull a toolbar down onto the scene to use it near the workpoint.
        But, I think you may mean to specify a selection set of toolbars that you can call up for a certain workflow?
        • HumpmetwiceH Offline
          Humpmetwice
          You could use the custom toolbars by Jim.
          http://sketchuptips.blogspot.com/2008/06/custom-toolbars-release-08-06-01.html
          Not sure if you could customize a tool bar for other plugins as you do the native tools?
            jsl
            Thanks,
            Will take a look at Jims toolbar plugin. If this allows to build custom toolsets in one toolbar, then might be just what I was thinking of.
            JSL
              It does. Great plugin, I use it.
