    Help with arrays
    11 Posts 3 Posters 634 Views 3 Watching
    • PixeroP
      Pixero
      I need to test each elements in one array (test_array) and if the test is true
      put elements from another array (array) in certain indexes of a new array (new_array).
      If that index is already "occupied" the new element should overwrite the current.
      How do I do it?
      Here is some pseudo code to explain what I want:
      	# Three arrays
      	# test_array
      	# array
      	# new_array
      	test_array.each { |i|
      		if test1==true
      			new_array[0] = array[i]
      		if test2==true
      			new_array[1] = array[i]
      		if test3==true
      			new_array[2] = array[i]
      		if test4==true
      			new_array[3] = array[i]
      • Dan RathbunD
        Dan Rathbun
        Your code is almost there.
        There is the .each_with_index method that may be more readable.
        test_array.each_with_index {|e,i|
        A question... does the data array contain beforehand, the same number of elements, as the new_array.
        If not, you need to use a hash with integer keys, instead of an array as the ouptut data.
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          Jan, what platform are you on, PC or Mac?
          • PixeroP
            Pixero
            PC.
            Thanks for your answer. Is my way of putting the element from array into new_array correct?
            What happens if a index is occupied? Is that element moved to the next index or simply overwritten?
            (new_array is empty, you could say I sort array into new_array.)
              The way I'd do it is probably not the proper way... but it'd work...
              ` tarray=[11, 22,33, 44]
              aarray=[1, 22, 333, 44]
              narray=Array.new(tarray.length)
              p narray
              [nil, nil, nil, nil]
              tarray.length.times{|i| narray[i]=tarray[i] if tarray[i]==aarray[i] }
              p narray
              aarray=[nil, 22, nil, 44]`
              This works if you want to match exact array entries BUT use ' array.include?(value)' if you simply want to find the entry anywhere in the arrays
              • Dan RathbunD
                Dan Rathbun
                No not with .each, but possibly using .each_with_index
                It is always overwritten when you use the [=] assigment method, and the index is occupied.
                The [=] assigment method will automatically insert nil (blank,) index members if you specify an index greater than those in the array.
                If the array is empty, and you do a[3='Jan'], the array will be [nil,nil,nil,'Jan']
                if the array was ['Bill','Dan'] and you do a[4='Jan'], the array will be ['Bill','Dan',nil,nil,'Jan']
                • Dan RathbunD
                  Dan Rathbun
                  @pixero said:
                  ..., you could say I sort array into new_array.
                  IF you REALLY want to sort to a new array, use new_array = old_array.sort
                  IF you wish to sort an array itself, use old_array.sort!
                  (notice the exclamation point.)
                  • Dan RathbunD
                    Dan Rathbun
                    @pixero said:
                    PC.
                    Do you have the Ruby Core Reference CHM (Windows Compiled Help HTML,) for Ruby 1.8.6 ??
                    If not download it from my post in the Ruby Resources topic
                    Notice at the top of each class or module, the Mixin Modules are listed.
                    Array class has Enumerable mixed-in, so it inherits all those methods.
                    • Dan RathbunD
                      Dan Rathbun
                      If you could tell us what kind of test your doing.. it would help us choose the proper Enumerable method for you.
                      I'm thinking probably the .collect method is perhaps what you want.
                      • PixeroP
                        Pixero
                        Its actually the continuation of this thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=33862
                        I have to digest this and try what you recommended before getting back.
                        • Dan RathbunD
                          Dan Rathbun
                          @pixero said:
                          Its actually the continuation of this thread: [url]=ttp://forums.sketchucation.com/viewtopic.php?f=180&t=33862]How to compare points on a plane?[/url]
                          OK.
                          So the data_array contains Geom::Point3d objects?
                          What kind of object does the test_array contain?
                          What is the logical condition that you want the data_array elements to be added to the new_array?
                          If a false results from the logical test, is putting nil into the new_array OK, or do you wish some other value (perhap [0,0,0] or whatever) ?
                          We need to be careful when comparing Geom::Point3d objects, as Google overrode the .< and .== methods (to make them dependant upon the 0.001" internal tolerance.) You should decide if that's OK for your purposes.
