    Help with componentdefinition=definitions.load name
    17 Posts 5 Posters 1.4k Views 5 Watching
    • honoluludesktopH Offline
      honoluludesktop
      I am having problems understanding using the method load in componentdefinition=definitions.load name where name is "filename.skp". When I run SU by clicking on a "filename.skp", the above creates a definition from the "filename.skp", but when I start SU, then select a file from another folder, the definition fails to be created. However when I start SU, then open a "filename.skp" in the folder that includes the shortcut to SU, a definition is created.
      How do I use the method in the situation above that failed.
        Jim
        I don't follow what your trying to do.
          honoluludesktop
          I have a file "filename.skp" that I would like to load in my model as a definition.
            I'm guessing you're not specifying an absolute path to the .skp file? Ensure you have given the full path to the file so SU doesn't have to guess where it is.
            • Dan RathbunD Offline
              Dan Rathbun
              It should not be using the method above, in this situation, SU should be using Sketchup.open_file
              You have a definition in the file you clicked on, because the file ALREADY had a definition in it before it was saved.
              SU is still using Sketchup.open_file
              Because there is no component IN the saved file, just simple geometry entities.
              I would think the definition, IN the file, was ALREADY created before the file was saved.
              I'm not here much anymore.
                Dan Rathbun
                BTW, if you drag and drop a skp (that has NO saved definition within it,) from the File Explorer, into the Sketchup model space, it gets imported AND converted to a definition "on-the-fly".
                The question would follow, what happens to a drag and drop, when the file DOES have a component? Is it nested?
                Answer YES.
                  honoluludesktop
                  I tried specifying an absolute path to the .skp file, but that failed.
                  Dan, I am still reading your post.
                    honoluludesktop
                    OK, let me try to explain better.
                    1a. I open SU, either by selecting a .skp, or 1b. the SU shortcut (then open a .skp from a folder that the SU plugin is not in).
                    2. I add a new .skp into the model as a component.
                    Where name is not the absolute path name, componentdefinition=definitions.load name creates a definition of the new .skp in the model in the case of 1a, but not 1b. When name is the absolute path name, both 1a, and 1b. fail.
                    I realize that not using the absolute path name seems wrong, but it worked, where using the absolute path name failed.
                      honoluludesktop
                      What this seems to be telling me, is that componentdefinition=definitions.load name works when the active SU::Model folder is the same as the new .skp file. Or, I am somehow not getting the correct absolute file name. My code is:
                      dir_name=File.dirname(model.path) name=dir_name+"\\"+filename+".skp"
                      I have checked the result by puts name, and it looks OK.
                        Jim
                        I don't think a Definition will load if a definition already exists with the same path. Is this what's happening?
                          Jim
                          Related?
                          404 Not Found
                          (forums.sketchucation.com)
                            honoluludesktop
                            Maybe, how do I check? How do I delete an existing definition?
                              honoluludesktop
                              @jim said:
                              Related?
                              404 Not Found
                              You posted while I was posting.:-) Went to viewtopic, but some of the discussion is "over my head". How do I cdef.save_as("/dev/null")? is "/dev/null", my "dive:/pathname/null"? Is cdef the existing cdef, or the new cdef?
                                honoluludesktop
                                More precicely:
                                1. I saved the transformations of a set of components.
                                2. Then deleted the components from the model.
                                3. Created a new definition from a new .skp.
                                4. Created components with the new definition and the saved transformations.
                                This cnt_instance.definition.save_as(File.dirname(model.path)+"\\null") returned, Error: #<TypeError: reference to deleted ComponentInstance>, where cht_instance is the deleted component.
                                I also tried definitions.purge_unused without success.
                                  Cleverbeans
                                  More precicely:
                                  Try switching steps 2 and 3. Once you delete the component referring to it will throw the error you're getting. If you require a reference to the instance in order to property do step 4, then add the new components to the model first and delete the old components afterwards.
                                    honoluludesktop
                                    Cleverbeans, Thanks, but didn't work.
                                      honoluludesktop
                                      Well, I completed my program, and did it by not using a path. It's my guess that SU keeps track of where SU is, so if you:
                                      1. Save a component to file as name.skp.
                                      2. Edit the saved file. (this is the function of the plugin)
                                      3. Erase the component instances (that was saved) from the original model entities.
                                      4. definitions.purge_unused
                                      5. componentdefinition = definitions.load name.skp
                                      6. entities.add_instance componentdefinition, each_transformation
                                      The key to make this work is step 4. The only problem that can come about is if you require the erased components to remain in the select "Components" window.
