    Help with componentdefinition=definitions.load name
    17 Posts 5 Posters 1.5k Views 5 Watching
    • honoluludesktopH
      honoluludesktop
      @thomthom said:
      @honoluludesktop said:
      How do I use the method in the situation above that failed.
      I'm guessing you're not specifying an absolute path to the .skp file? Ensure you have given the full path to the file so SU doesn't have to guess where it is.
      I tried specifying an absolute path to the .skp file, but that failed.
      Dan, I am still reading your post.
      • honoluludesktopH
        honoluludesktop
        OK, let me try to explain better.
        1a. I open SU, either by selecting a .skp, or 1b. the SU shortcut (then open a .skp from a folder that the SU plugin is not in).
        2. I add a new .skp into the model as a component.
        Where name is not the absolute path name, componentdefinition=definitions.load name creates a definition of the new .skp in the model in the case of 1a, but not 1b. When name is the absolute path name, both 1a, and 1b. fail.
        I realize that not using the absolute path name seems wrong, but it worked, where using the absolute path name failed.
        • honoluludesktopH
          honoluludesktop
          What this seems to be telling me, is that componentdefinition=definitions.load name works when the active SU::Model folder is the same as the new .skp file. Or, I am somehow not getting the correct absolute file name. My code is:
          dir_name=File.dirname(model.path) name=dir_name+"\\"+filename+".skp"
          I have checked the result by puts name, and it looks OK.
            Jim
            I don't think a Definition will load if a definition already exists with the same path. Is this what's happening?
              Jim
              Related?
              http://forums.sketchucation.com/viewtopic.php?f=180&t=28122
              • honoluludesktopH
                honoluludesktop
                Maybe, how do I check? How do I delete an existing definition?
                • honoluludesktopH
                  honoluludesktop
                  @jim said:
                  Related?
                  You posted while I was posting.:-) Went to viewtopic, but some of the discussion is "over my head". How do I cdef.save_as("/dev/null")? is "/dev/null", my "dive:/pathname/null"? Is cdef the existing cdef, or the new cdef?
                  • honoluludesktopH
                    honoluludesktop
                    More precicely:
                    1. I saved the transformations of a set of components.
                    2. Then deleted the components from the model.
                    3. Created a new definition from a new .skp.
                    4. Created components with the new definition and the saved transformations.
                    This cnt_instance.definition.save_as(File.dirname(model.path)+"\\null") returned, Error: #<TypeError: reference to deleted ComponentInstance>, where cht_instance is the deleted component.
                    I also tried definitions.purge_unused without success.
                    • C
                      Cleverbeans
                      More precicely:
                      Try switching steps 2 and 3. Once you delete the component referring to it will throw the error you're getting. If you require a reference to the instance in order to property do step 4, then add the new components to the model first and delete the old components afterwards.
                      • honoluludesktopH
                        honoluludesktop
                        Cleverbeans, Thanks, but didn't work.
                        • honoluludesktopH
                          honoluludesktop
                          Well, I completed my program, and did it by not using a path. It's my guess that SU keeps track of where SU is, so if you:
                          1. Save a component to file as name.skp.
                          2. Edit the saved file. (this is the function of the plugin)
                          3. Erase the component instances (that was saved) from the original model entities.
                          4. definitions.purge_unused
                          5. componentdefinition = definitions.load name.skp
                          6. entities.add_instance componentdefinition, each_transformation
                          The key to make this work is step 4. The only problem that can come about is if you require the erased components to remain in the select "Components" window.
