    Mac Toolbars Editable?
    15 Posts 7 Posters 3.2k Views 7 Watching
      driven
      thanks Jeff,
      I use to have them 'stay' in V7 by doing that, but I'd completely forgotten it was a workaround...
      that you probably suggested in the first place...
      • wind-borneW
        wind-borne
        Does anyone know if the 'measurements box' png in the Mac toolbar is accessible and editable?
        I like the box top center yet frown upon the word invading the landscape. 😲
        "To read between the lines was easier than to follow the text."OSX 10.11.6
        %(#BF80BF)[SU 8 pro
        • Dan RathbunD
          Dan Rathbun
          On PC its not a png, it's dynamically generated text. It changes (because it's a prompt,) depending on the Tool in use, and what step you are at in the Tool.
          In fact there are Ruby methods to set the VCB text prompt for coders writing their own Tool plugins.
          VCB = Value Control Box (another name for the Measurements Control.)
          I'm not here much anymore.
          • wind-borneW
            wind-borne
            Duh,
            I always just looked inside the box but now I see words outside changing to reflect the action.
            %(#BF80BF)[SU 8 pro
              driven
              it's that the plugins folder, i assume, is accessed later in the launch sequence than the toolbar being made..
              try this:
              put a ruby icon in the custom toolbar
              quit sketchup
              launch sketchup (the icon won't be up there at this point)
              open a new window (there's the icon)
              I also remembered the 'auto activate paint tool' preference 'bug' stops if your doing this and have also added a shortcut to Model Info window... to stop it popping up when you hit the space bar (set for 'select'), after using paint bucket.
                Jim
                try this:
                quit sketchup
                Ah, thanks - this is what I had missed. Each Ruby Command on a Toolbar does show up as an individual item on the Mac custom toolbar dialog, but sometimes not in the first opened window. It would suggest there's a timing issue.
                Each platform seems to have half the solution. Users need to be able to create their own Toolbars (or Tool Palettes on Mac), and also be able add/remove individual Commands from it.
                  I did some more work on my Menu and Toolbar hack today. Got full hierarchy of Menus with access to menu text and procs. It would be possible to intercept the creation of the menus and place them at custom locations. Same thing can be done to toolbars.
                  Just want to make a quick Webdialog to go along with the proof of concept - then I'll post it here in the developers section so we can have collective review and brainstorming.
                    Jim
                    Also, are Mac Toolbars always vertical? In Windows, you can drag their border to change their aspect.
                    Oop, nevermind - drag them to the edge of the screen and they change automatically.
                      driven
                      jim, thom
                      you can edit the nibs on NSPanels, and I guess you could change the content if you know all the tool codes...
                      bit tricky getting transparent backgrounds right for each button
                        How did you do that?
                          driven
                          I've sent a PM, you need Xcode and interface builder, and know where to find the files...
                          I'm not sure if 10.6 lets you, but 10.5.8 does, there not locked, just buried...
                          • H
                            haynesc
                            @driven said:
                            jim, thom
                            [attachment=0:1e21rm0n]<!-- ia0 -->tool palettes .jpg<!-- ia0 -->[/attachment:1e21rm0n]
                            hi i want this can you show me how?
