    How to compare points on a plane?
    17 Posts 6 Posters 980 Views 6 Watching
    • PixeroP Offline
      Pixero
      I have points on a plane and I would like to find out which is max in custom axis x and y.
      I have the vectors for the custom x and custom y axis but how do I use it to see if a point is larger in that custom axis?
      The points are point3d with world position but the world position can't be used in this case.
        I take it you have a point of origin as well?
        <span class="syntaxdefault"><br />origin </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword"><</span><span class="syntaxdefault">some_point</span><span class="syntaxkeyword">><br /></span><span class="syntaxdefault">x_axis </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword"><</span><span class="syntaxdefault">some_vector</span><span class="syntaxkeyword">><br /><br /></span><span class="syntaxdefault">x_line </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">origin</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> x_axis</span><span class="syntaxkeyword">]<br /><br /></span><span class="syntaxdefault">max_pt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> nil<br />max_dist </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> nil<br />for pt in pts<br />  pt_on_line </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">project_to_line</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> x_line </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  distance </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> origin</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">distance</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> pt_on_line </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  if max_pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">?</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">||</span><span class="syntaxdefault"> distance </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> max_dist<br />    max_pt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> pt<br />    max_dist </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> distance<br />  end<br />end </span><span class="syntaxcomment"># for<br /><br /></span><span class="syntaxdefault">puts </span><span class="syntaxstring">"The point furthest away on the X axis from origin is #{max_pt}"<br /></span><span class="syntaxdefault"> </span>
        (untested)
          Oh wait - I think I've completely misread your illustration! 😳
            Max - as in furthest away? From which point?
            Is your plane parallel to the camera?
            Right - so you need to project your points to that plane. (If I understand you correct.)
            <span class="syntaxdefault"><br />plane&nbsp;</span><span class="syntaxkeyword">=&nbsp;<</span><span class="syntaxdefault">some_plane</span><span class="syntaxkeyword">><br /></span><span class="syntaxdefault">projected_pts&nbsp;</span><span class="syntaxkeyword">=&nbsp;{}<br />for&nbsp;</span><span class="syntaxdefault">pt&nbsp;in&nbsp;pts<br />&nbsp;&nbsp;projected_pts</span><span class="syntaxkeyword">[&nbsp;</span><span class="syntaxdefault">pt&nbsp;</span><span class="syntaxkeyword">]&nbsp;=&nbsp;</span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">project_to_plane</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">plane&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">end<br /></span>
            Then you have a set of points you can use to measure distances related to your axes.
            (btw, what is the higher function of this? Might make it easier to understand your problem.)
            • simon le bonS Offline
              simon le bon
              @pixero said:
              I have points on a plane and I would like to find out which is max in custom axis x and y. ❓
              I absolutely don't understand the problem 😆
              Is that can help?
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/PixeroComparePointsOnaPlane-1.jpg
              ❓ s
              • PixeroP Offline
                Pixero
                Thomthom, see PM.
                • Didier BurD Offline
                  Didier Bur
                  I think you'll have to write a "world_to_local" axis function, using the 'Transformation.axes' method.
                  Happy new year !
                  DB
                  • Dan RathbunD Offline
                    Dan Rathbun
                    The simpliest means is to use the methods that are inherited by the Array class, from the Enumerable and Comparible mixin modules, along with the built in .x and .y methods of the Geom::Point3d class.
                    ** keep in mind that the function returns the FIRST max.
                    given some points pt1, pt2, pt3, pt4, pt5 of Geom::Point3d
                    <span class="syntaxdefault"></span><span class="syntaxkeyword">array=[</span><span class="syntaxdefault">pt1</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">pt3</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">pt2</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">pt4</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">pt5</span><span class="syntaxkeyword">]<br /></span><span class="syntaxcomment"># the Enumerable.max block form using <=>,<br /># returns whatever class the members are.<br /></span><span class="syntaxdefault">x_max_pt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> array</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">max </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">b</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword"><=></span><span class="syntaxdefault"> b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">y_max_pt </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> array</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">max </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">b</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y </span><span class="syntaxkeyword"><=></span><span class="syntaxdefault"> b</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault"> </span>
                    You can also use Enumerable.min to find the FIRST member with the minimum.
                    If you wish to know after the above test, if any other points have equal x or y coords ... you will have to again go through the array, using the coord (x or y,) as a test:
                    <span class="syntaxdefault"></span><span class="syntaxcomment"># Enumerable.find_all returns an Array<br /></span><span class="syntaxdefault">pts_with_max_x </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> array</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_all </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> x_max_pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">x </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">pts_with_max_y </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> array</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">find_all </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> y_max_pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">y </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault"> </span>
                    THEN you'll need to test the resultant array(s) length, to see if you have more than 1 max point, respectively, and do whatever ... make a choice somehow.
                    I'm not here much anymore.
                      Dan Rathbun
                      FYI.. beware Point3d.< and Point3d.== were overriden in the Geom::Point3d class, and may not give you the same results you'd expect from standard Ruby objects.
                        Cleverbeans
                        Since you have the vectors defining your x and y directions, you can get a third by taking their cross product giving you to get the vector normal to the plane giving you a custom z as well. For the purposes of finding the points with maximal custom x and y values you can choose any point in the plane as an origin since the relative position of the other points will not change depending on your selection.
                        The Transformation.new method can take an origin and three axis as arguments. This transformation can be thought to take the world x,y,z axis and turn them into the custom axis your plane defines. The idea is to transform your points using the inverse of this transformation, which will lay them neatly in the world x-y plane. Then you can find the maximum by comparing the x and y values in the usual way, and then do the transformation on the points once you've identified them to retrieve the points you want. Here is a function which you can tailor to your needs.
                        def custom_max_x_and_y(custom_x,custom_y,pt_array)
                            custom_z = custom_x.cross(custom_y)
                            trans = Geom;;Transformation.new(pt_array[0],custom_x, custom_y, custom_z)
                            new_points = pt_array.map{|pt| pt.transform(trans.inverse)}
                            max_x = new_points[0]
                            max_y = new_points[0]
                            for pt in new_points
                                if pt.x > max_x.x then
                        		max_x = pt
                        	if pt.y > max_y.y then
                        		max_y = pt
                            return max_x.transform(trans), max_y.transform(trans)
                          Dan Rathbun
                          @cleverbeans said:
                          Then you can find the maximum by comparing the x and y values in the usual way, ...
                          > 		max_x = pt
                          > 	end
                          > 		max_y = pt
                          > 	end
                          >     end
                          Why use slow interpreted Ruby to wite your own interator, when the example I gave above, uses the compiled C interator that all Array objects inherit from module Enumerable?
                              max_x = new_points.max {|a,b| a.x <=> b.x }
                              max_y = new_points.max {|a,b| a.y <=> b.y }
                          Again.. however this assumes that only 1 point will be at maxiumum x and/or y. (If it matters, see my post for the find_all test.)
                            Cleverbeans
                            In general I find it superior to use code I understand to code which I find opaque. Ruby's syntactic quirks are still something of a mystery to me, and I didn't want to present code I couldn't explain. I'll definitely want to take advantage of the method you've presented however since I'm doing similar things in my current project. On that note, it appears there are two independent iterations over the same collection occurring here.
                            Is there a means of bundling them into a single traversal?
                              Cleverbeans
                              It's nice to see that the enumerable class supports so many functional methods. Thanks for pointing it out.
                                Dan Rathbun
                                That's OK if speed is not an issue .. especially a first go around and you wish to just prove a concept. (Optimization can always come later.)
                                @cleverbeans said:
                                ... it appears there are two independent iterations over the same collection occurring here.
                                True.. I might argue that it still may be faster, as the iteration vars are created and managed on the C-side.
                                The only way to know is to test it out. (The answer would be valuable for the Optimization topic.)
                                Yes I believe you could using the Enumerable.inject method.
                                # pts is an array of Geom;;Point3d objects
                                # the returned array will be max_xy_pair = [max_x_pt,max_y_pt]
                                # set initial mem var to array whose 2 elements are the 1st pt
                                max_xy_pair = pts.inject([pts[0],pts[0]]) {|mem,pt|
                                  # this array below is returned as var mem on each loop
                                  [ mem[0].x>pt.x ? mem[0];pt, mem[1].y>pt.y ? mem[1];pt ]
                                EDIT - TESTED at Console:
                                ** pts=[pt1,pt2,pt3,pt4,pt5,pt6]
                                [Point3d(1, 2, 3), Point3d(0, 2, 3), Point3d(3, 1, 2), Point3d(5, 6, 7), Point3d(4, 2, 1), Point3d(6, 1, 8)]
                                max_xy_pair = pts.inject([pts[0],pts[0]]) {|mem,pt| [ mem[0].x>pt.x ? mem[0]:pt, mem[1].y>pt.y ? mem[1]:pt ] }
                                [Point3d(6, 1, 8), Point3d(5, 6, 7)]**
                                Looks like it works. (I was afraid after looking at the C source that the 1st arg, initial had to be an integer.) So I thought I should do a quick test.
                                P.S. - Do you have the Standard Ruby Core CHM Reference ?
                                If not, get it in the Ruby Resources topic.
                                  Cleverbeans
                                  So I ran some test this morning, and surprisingly the code I presented appears to be the fastest. Here is the code I used to test it.
                                  First Method
                                  def first_test(pts)
                                      xmax = pts[0].x
                                      ymax = pts[0].y
                                      for p in pts
                                  	if p.x > xmax then
                                  	    xmax = p.x
                                  	if p.y > ymax then
                                  		ymax = p.y
                                      return xmax,ymax
                                  Second Method
                                  def second_test(pts)
                                      return pts.inject([pts[0],pts[0]]){|mem,pt| [ mem[0].x>pt.x ? mem[0];pt, mem[1].y>pt.y ? mem[1];pt ]}
                                  Third Method
                                  def third_test(pts)
                                      xmax = pts.max{|a,b| a.x <=> b.x}
                                      ymax = pts.max{|a,b| a.y <=> b.y}
                                      return xmax,ymax
                                  The Testing Routine
                                  def the_test()
                                      pts = []
                                      for x in 0...10000000
                                  	pts.push(Geom;;Point3d.new(rand,rand,rand))
                                      start = Time.now()
                                      first_test(pts)
                                      finish = Time.now()
                                      interval = finish.to_i - start.to_i
                                      puts("First Time; " + interval.to_s)
                                      start = Time.now()
                                      second_test(pts)
                                      finish = Time.now()
                                      puts("Second Time; " + interval.to_s)
                                      start = Time.now()
                                      third_test(pts)
                                      finish = Time.now()
                                      puts("Third Time; " + interval.to_s)
                                      return "Complete."
                                  Results
                                  qt()
                                  First Time; 18
                                  Second Time; 61
                                  Third Time; 56
                                  Complete.
                                  Truth is stranger than fiction sometimes.
                                    If you converted the first one to use each instead of for - would it still be as fast? I wonder if it's Ruby's overhead of creating variables that might play a part in this.
                                      Dan Rathbun
                                      Perhaps the time to make the method call? Hmm.. but they are called only once or twice.
                                      It doesn't make sense... the 1st test is what inject does but in C code:
                                      rb_iterate(rb_each, obj, inject_i, (VALUE)&memo);
                                      and this is max, in 😄
                                      rb_iterate(rb_each, obj, rb_block_given_p() ? max_ii ; max_i, (VALUE)&result);
                                      We should run the test several times in different orders.
