    Aerospatiale SA-2 Samson
    24 Posts 12 Posters 6.5k Views 12 Watching
    • FrederikF Offline
      Frederik
      Really nice, Liam...
      But you seem to have an issue with the geometry...
      In some places it loos as if the surface isn't smooth...
      How does it look in SU...??
      I would assume that you can eliminate it completely from the renders...
      Cheers
      Kim Frederik
      • N Offline
        notareal
        Some smoothing issues indeed. Are you using latest Thea RV446 http://www.thearender.com/forum/viewtopic.php?f=61&t=1849 as it does handle terminator artifacts fairly well. If smoothing is not exported correctly from SU (for my understanding it should export just fine when default SU smoothing is used), you could give 30 degrees geometry smoothing inside Thea.
        • massimoM Offline
          massimo Moderator
          if I can render this at 10% of the level of your cups model it will be even better
          Maybe...And if I can model at 10% something like your helicopter I would be pretty happy. πŸ˜‰
            liam887
            yeah its not a problem, parts of the model with issues are just parts im still working on πŸ˜„
            VISIT MY ONLINE GALLERY
              meak
              I've always admired your work. β˜€
              small details, and the general impression of reality.
                TonyLloyd
                That is beautiful πŸ˜„ I like the nod to Weyland-Yutani in the title bar too πŸ˜„
                Is this going to be released into the public domain ? I'm trying to build a radio-controlled version of the Samson, but my draughting skills are severely lacking and trying to find good quality images from which to take dimensions is proving harder than I thought.
                  liam887
                  I will release it eventually when its finished but in the meantime I could make some orthographic plans for you to work with if you want? I thought about making a RC version but I dont have the skills for a dual ducted fan model. I have a scale spitfire its pretty big with an 6ft wingspan but not finished as I havent had any spare change to buy a two stroke engine of multi channel RC controller those things are expensive 😲 so its on ice in the attic for now, good luck with it however! Contact me via email if you want to sort out some scale plans liamk887@gmail.com. Here are some simple orthos of the basic shape if they are any help.
                  More work on the samson, have replaced the rocket launchers with extra tanks for more fuel as this version will probably be a search and rescue so no need for weapons.
                  • soloS Offline
                    Ooooh! these are great, screaming for a Thea render.
                    If you have not got the time...I do (hint). πŸ˜‰
                      liam887
                      Here are some shots of the other two helicopters for some scale comparison. I have stripped out the interiors and tiny details from all three (thank god for layers) to make the file smaller do they all fit on the screen at once without melting the computer.
                      Im going to do some illustrative renders like I did for the batman tumbler http://liam887.files.wordpress.com/2010/07/final-shot1.jpg
                      but the newest version of the search and rescue will have the full works in Thea. I only have access to my laptop right now so dont expect anything special ill probably just be playing with materials and lighting for the next few weeks.
                        liam887
                        Yeah I was eventually going to be cheeky and just ask you to do it for me lol πŸ˜† and them make a background in vue
                        Its still got a lot of work to do but im making a test model for thea, basically stripping the interior and closing the doors and windows and using the lighter model to test materials and environments on my already strained laptop. Ill email you the file next week will have finished it by then.
                        I also need to update my Thea im about two releases behind doh!
                        • soloS Offline
                          Sounds great, I'm game.
                            jimi james
                            Nice work on the different versions of the Samson. I'm not sure which one I like best, but they're all pretty cool.
                            The New Haven Chronicles
                            "And we will fight." -- Secretary General Alvaro Masai
                              dolphus
                              Can't wait to see the Liam /Solo colaboration on a faboulous chopper exelent work liam πŸ‘
                                liam887
                                me neither! although NYE celebrations have set me back weeks I lost a lot of grey matter last night πŸ˜’
