    [REQ] manipulate camera by something like mover2 ?
    8 Posts 4 Posters 2.2k Views 4 Watching
    • bagateloB Offline
      bagatelo
      One more of the series "Alex and their crazy ideas.... " 🤣
      Would it be possible to control the camera of Sketchup using something similar to the tool "Mover2?"
      http://sketchuptips.blogspot.com/2007/08/plugin-mover-2.html
      Set camera offset for rotation and translation numericly:
      http://www.pixero.com/downloads_sketchup.html
      http://www.smustard.com/script/CameraControls
      I think something like move camera "up/down", "front/behind", "right/left" by typed numeric values.
      Please, visit my blog: http://cg-alex.blogspot.com/
        Jim
        I will look into adding the Camera as a movable target using the mover2 controls. Give me a couple days..
          driven
          hi Jim,
          if your revisiting Mover2, could you add .show_modal for us mac users, I can't figure out how to (I'm sure I added it before)
          cheers
          • Dan RathbunD Offline
            Dan Rathbun
            if RUBY_PLATFORM.include?('darwin')
              dialog.show_modal()
            else
              dialog.show()
            You can get fancier with a global like $MAC_SHOW_MODAL_DIALOGS=true
            So the user can change their preference on the fly.
              if $MAC_SHOW_MODAL_DIALOGS
                dialog.show_modal()
              else
                dialog.show()
            else
              dialog.show()
            I'm not here much anymore.
              driven
              @dan rathbun said:
              ....That way way you would not need to badger every plugin coder to modify their plugins.
              cheers Dan, I'll give it a try, I usually just change them myself, but sometimes can't figure out 'where' to when people use super instead of UI::WedDialog
              I don't understand what super is... or where it comes from...
              btw. merry xmas to all
                Dan Rathbun
                Actually it would be "more proper" to have the control var as a class varible rather than yet another in the multitude of globals.
                I'll edit the code posting above.
                  Dan Rathbun
                  Hey John it occurs to me that YOU can override your UI::WebDialog class and force any call to show() to actually call show_modal(). You would use method aliaising, based on the global var.
                  Something like this: EDITED
                  class UI;;WebDialog
                    @@ALWAYS_SHOW_MODAL=false
                    def self.always_show_modal?
                      @@ALWAYS_SHOW_MODAL
                    def self.always_show_modal=(arg)
                      @@ALWAYS_SHOW_MODAL=arg
                    alias_method( ;old_show, ;show )
                    def show(&block)
                        if @@ALWAYS_SHOW_MODAL
                          show_modal(block)
                        else
                          old_show(block)
                      else
                        old_show(block)
                    end # show() override
                  end # class override
                    UI.menu("View").add_separator()
                    UI.menu("View").add_item('Show WebDialogs as Modal') {
                      if UI;;WebDialog.always_show_modal?
                        UI;;WebDialog.always_show_modal=(true)
                      else
                        UI;;WebDialog.always_show_modal=(false)
                  Made control var a class var, instead of a global.
                  Added menu option under View menu.
                    Dan Rathbun
                    super is a Ruby keyword that acts similar to a method, but has a quirk.
                    super
                    calls the same method in the ancestor PASSING UP the parameters that the child method received.
                    super()
                    calls the same method in the ancestor BUT PASSES AN EMPTY parameter list.
                    super(arg1, arg2, ...)
                    calls the same method in the ancestor BUT PASSES ONLY the parameters listed.
