    Latest Work with Curved Roof Design
    31 Posts 9 Posters 6.0k Views 9 Watching
    • F Offline
      fbartels
      xrok, the major problem with your approach is that the triangles forming the roof surface actually intersect over the center of the pipe, and to make this happen the beams need to attach to the pipe circumference at different heights from the top of the pipe. The attached images should help to make this clearer. Fred
      • X Offline
        xrok1
        could you not cut the top of the pipe at an angle?
        or slot the lumber:
        • X Offline
          xrok1
          😆 how can it be simple when it looks like you would need a degree to figure out those non uniform triangles?
          anyway, all the best with your project.
          • F Offline
            fbartels
            xrok1, Some interesting ideas! There are obviously multiple ways to solve this problem. What I'm aiming for is hub hardware that is simple, easy to work with, and strong. Your ideas are definitely heading in that direction. Fred
            • TaffGochT Offline
              TaffGoch
              Fred,
              Further simplification, using thinner galvanized plate (the same stuff of which joist hangers are made.)
              Bracket/hanger
              The bolt can be more-simply replaced with a long clevis-pin, making assembly much easier/faster (possibly cheaper, too.)
              Clevis pin
              This is pretty close to your original connector design, and can be bent, using a jig and hydraulic press (jack) or vise & hammer. Since it's made of "plate" material, it doesn't have to be as thick as the straps in my first model. Additionally, it permits a more intimate strut-to-pipe fit.
              Taff
              Bracket & bolt
              "Information is not knowledge." -- Albert Einstein
              • TaffGochT Offline
                TaffGoch
                xrok1,
                Those tiger-grain oak struts should provide for a very impressive (and expensive) ceiling !
                • X Offline
                  xrok1
                  thats all i could find in the garage! 😆
                  • F Offline
                    fbartels
                    Taff,
                    Nice clean simple design. Now we just need to get it manufactured in volume. If you get a patent then Simpson will consider.
                    Invalid URL
                    (www.strongtie.com)
                    Fred
                    • N Offline
                      notareal
                      Maybe useable...
                      http://www.strongtie.com/products/connectors/bc.asp
                      if pilot hole is used with bolt, sure you should not, but I think it this case it wount be an issue.
                      • F Offline
                        fbartels
                        Had the opportunity to develop my curved roof ideas during an online course on Green Roofs offered by the Boston Architectural College.
                        Additional images here: http://dws.editme.com
                        Still working on a hub connector and a number of other components of this building approach but making slow and steady progress. Another five years, who knows?
                        Any leads, comments, feedback much appreciated.
                        Thanks, Fred
                        House 2.1 rafters roof surfaces.skp
                        • 2 / 2
