โ ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
Projected Textures not projecting
Morning
1st post
I'm following this guide on Youtube for projected textures, not for any real reason, just to learn.
I'm using Sketchup 8 and when it comes to pressing the Alt key to sample the texture SU seems to reset the image position, or default the texture to white.
To check I'm wasn't going nuts, I have tried the guide using SU7 on my works PC and the guide works perfectly.
Any pointers?
Did you try exactly with the same model?
What video card do you have? What happens if you disable hardware acceleration under Window > Preferences > OpenGL settings (and are the two versions have the same settings there)?
Oh, and welcome to SCF!
