    [Plugin] Selection Toys
    594 Posts 121 Posters 499.1k Views 121 Watching
      rv1974
      Hi Thom!
      Unfortunatly those toys grey out my right click menu (or in more ballanced words deleting of all toys
      files\folders solve this problem). Could you take a closer look at the issue?
      I need them badly
      Thank in advance.
      P.S. I'm talking about the last version of the toys + lib.
        Have you got a large number of plugins?
        Have you updated all Fredo plugins?
        Download the .rb file in this post: http://forums.sketchucation.com/viewtopic.php?f=323&t=29032&start=15#p252902
        Open the Ruby Console
        And type stats after you right click on various items.
          rv1974
          1. yes
          2. yes
          3. stats
            UI:Command objects: 337 of 1000 (33.70%)
            Does the stats number remain flat like that during a modelling session? (right-click on various items and check with stats after each right click.)
            Are the menu's disabled immediately after SU loads? Or does it happen later in the modelling session?
            Have you had ST installed previously?
              rv1974
              First off after reinstalling the menu is OK (on the first munutes of the work)
              The stars numbers are floating from 477 to 491 (with "menu optimizer" preinstalled), and remain
              constant 337 after the "menu optimizer" uninstalled.
              Usually the menu get disabled after some period (may be 30 min - 300 min it's hard to say).
              But today it happened on the start.
              Once more: meanwhile everything is OK but the time will show.
              Edit: after ~10 min the menu is grey 😞 (the "menu optimizer" does not improve the state).
                Can you remove Selection Toys and the Menu Optimizer and try stats without them?
                Right click on various types of geometry, Edge, Face, Group, ComponentInstance, Image and see if the number stats return increases.
                  rv1974
                  It remains constant (UI:Command objects: 250 of 1000 (25.00%)) on different type\number of entities.
                    250 without, and 477 to 491 with... πŸ˜•
                    You are using the latest, yes? Not an older version?
                    And SketchUp version...?
                    OS?
                    I wonder if there is a combo of plugins that does this. As I can not reproduce it.
                    Can you post a screenshot of your plugins folder, with small icons side by side so I can get an idea of how many plugins you got?
                      rv1974
                      In this case I'm on XP.
                      As for my plugin folder check your mail box
                        I'm very stomped on this.
                        It could be that you have more plugins with menus/toolbars that SU can deal with - and installing Selection Toys, which feature a number of UI items is causing the glass to flow over.
                        I'll try to poke some Googlers to hear if they have a theory - or if there are any way to track this down.
                        Unfortunately I'm going away for a few days - so I won't be able to follow up on this immediately.
                        You could try to turn off menus in Selection Toys you know you won't use.
                        And until this can be properly resolved, disable unused/ rarely used plugins.
                          reza1615
                          I can not load it in SU 8
                          it has this error at Sketchup's beginning.
                          Error Loading File tt_selection_toys.rb
                          no such file to load -- TT_Lib/core.rb
                          REZA
                            Hi Reza,
                            Did you install the TT_Lib library as I suggested? Also, linked from the very first post in this topic, there is a quite new version of it - maybe that is needed.
                            (Thomthom, can you suggest? Reza started with the plugins from Didier's depot but the versions may be confused)
                              The error is because TT_lib is not installed, or not installed correctly.
                              I have not been aware the my plugins was available at the depot. I have had nothing to do with that so I do not know what version. I saw there was many or all of them there - but the version info is scares. Got to say I'm surprised to see them there and I'd prefer if they wheren't as I have no control of their updating...
                              SCF is at the moment the only official distribution channel for my plugins.
                                reza1615
                                Please add "select unselected objects" or "Invert Selection"
                                Thank you for your nice tool
                                REZA
                                  Well, contact Didier then. There are other authors who prefer to keep their plugins on their sites (like Jim) or here and Didier only places links to those plugins.
                                  So Reza, have you installed the TT_Lib library as I suggested?
                                    reza1615
                                    @gaieus said:
                                    Hi Reza,
                                    Thank you. yes it works now .
                                    but that link doesnt exist (broken) i got this plugin from this site.
                                    thank you for your supports
                                    I have some sugestions for this plugin please add
                                    1- free line drawing selection is useful.
                                    for example: user moves clicked mouse over objects and each one detects mouse pointer they will be selected
                                    2-search by name
                                    3-making selection set list
                                    4-Invert selection (select unselected)
                                    thank you for your nice tool
                                    REZA
                                      Which link didn't work?
                                      I'll be doing Selection Toys 3 at some point where I'll be adding more features.
                                        I guess this one:
                                        http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=680
                                        Under here, the info does not indicate that Selection Toys need TT_Lib:
                                        http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=609
                                        (I do not know what versions they are all by the way).
                                        Here is the original Help Forum topic we started with Reza from:
                                        http://www.google.com/support/forum/p/sketchup/thread?tid=1bf4956ba294a67a&hl=en
                                          danbig
                                          For some reason, I can't get the component selection tool to work.
                                          I'm selecting a single instance of the component, then choosing instances > select all from the context menu. Nothing happens.
                                          This has to be something obvious that I'm not seeing?
                                          Thanks in advance.
                                            And there are more instances? Or is it unique?
                                            Do you have a sample model where you can reproduce this, and share here?
                                            (If you open the Ruby Console, does there appear errors when you use the plugin?
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 29
                                            • 30
                                            • 18 / 30
