๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
How to rotate North in SU8 Free? (plugin request ?)
8 Posts 5 Posters 1.7k Views 5 Watching
    derei
    Well ... I tested SU8 Pro and my testing hours are gone (third time ๐Ÿ˜„ ) - and I am happy to go back to Free.
    But, there was something nice in PRO: Solar North - nice at first sight, but not so nice after deeper look, because the only way I could use it, was by entering North Angle as a value. The visual rotator crashed SU every time.
    Is any plugin that can visually rotate North in FREE version? I am not interested in real geo-location, but adjusting North direction to control where the Sun is. If isn't, would be difficult do make one?
    • H Offline
      honoluludesktop
      Can't you rotate the model? Just select all, group, then rotate it.
        derei
        Yes I can... but if it's a really big model it will be hard to rotate. And most of all, If I want to see how the shadow will fall from rendering view, it's a little hard, don't you think? ๐Ÿ˜„ To rotate the model, then switch back to preset scene, then rotating again...and so on.
        Why do you ask this? is it difficult to rotate using ruby?
        • H Offline
          honoluludesktop
          Don't know, haven't tried it. I think the Ruby Class to do this is here . Did you try a search for one?
            Didier Bur
            Latitude and longitude aren't enough to set the sun correctly. I've a script to orient the model in SU6 free (long time ago...)
            Download it here: http://rhin.crai.archi.fr/rubylibrarydepot/plugin_details.php?id=169
            Try it in SU8 (I have not SU8 ๐Ÿ˜ณ )
            And for latitude/longitude, you also have this: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=737
            These may also help: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=432
            http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=617
            Hope this helps,
            DB
            • H Offline
              honoluludesktop
              Posted this one before seeing the previous post. Oh well,,,,,,,,
              • O Offline
                Oxer
                See this web http://www.cerebralmeltdown.com/projects/sunplugin/ , you can download free plugin Sun Position, with this plugin you can change the angle North and hide/show it and you can see the sun position in your model with different options.
                I hope this help you, bye.
                  Also Jim's Model Location plugin .
                  http://bp1.blogger.com/_ogonR-k5OoM/R9vDZmq-pTI/AAAAAAAAHTU/bITaeqxMPL4/s1600-h/ss.jpg
                  It's an ancient one from the time when adding manual location was not possible in the free version of SU. Time to dust it off?
