    Programming Method
    5 Posts 3 Posters 399 Views 3 Watching
    • honoluludesktopH Offline
      honoluludesktop
      At best, the way I program typically involves a primary nested loop, and procedural calls. I also use a ton of "flags" to transmit conditions through out the code. All of this is OK until I begin to patch the program to correct bugs, or add enhancements. After a while the code becomes difficult to follow because I have forgotten the function of the flag, the patch, and the documentation begins to be obtuse.
      Any advice on organization from those with experience?
        Comment Comment Comment - the alpha and omega for maintaining code.
        Instance variables?
        I used to have a bunch of those as well - but now I try to make more custom classes that takes care of it's own section of the code.
          honoluludesktop
          Custom Classes? Guess I am not there yet. Just beginning to understand that methods are procedures>_< While I conceptually understand parent child, I don't have a clue as to implementing it. Will I live long enough?-)
            Jim
            A concrete example here, but I noticed in your dxf plugin you would benefit from using elsif instead of else if - it would greatly reduce the indenting in a few cases and make the code more read-able.
            Each if requires an end, so using elsif you could eliminate quite a few end statements.
            if condition
              # do this
            elsif condition
              # do that
            elsif condition
              # do the other
            else
             #  default action
              honoluludesktop
              Jim, Thanks again:-)
