    Select center of circle
    14 Posts 7 Posters 11.0k Views 7 Watching
      I was looking for the one of ThomThom.
      The other one (centerpoint) is also very useful, quick tool.
      Anyway, thanks guys for the speedy replies (I am getting older and cannot remember every plugin).
      ๐Ÿ˜„
      • ely862meE Offline
        ely862me
        Eh,I just discovered it ... viva the search button ๐Ÿ˜† .
        Aging is like the good wine,the older it is the better becomes.
        Elisei (sketchupper)
        Come and See EliseiDesign
          Yes, if you know whatyou are searching for!
          ๐Ÿ˜ฎ
            Marty
            All,
            Thanks for the replies. I installed the TomTom plug in (Guide Tools). It worked for adding a construction point to the center of a circle (when sketchup still "knows" it is a circle). However, it didn't add any construction points after I extruded it to a cylinder (cirle exploded). I tried both the top closed face (selecting all segments, some segments, face, and face + all segments) and the open bottom face (all segments & some segments). I used the "Guide Tools - CPoint at Exploded Arc" option (I tried most of the other options as well).
            Am I doing something wrong? I first select the entities and than the plugin tool.
            I also installed the Centerpoint plug in. It worked when I could select a closed face (top of cylinder). When I selected all the segments on the bottom, open face, it placed the construction point on the edge instead of the center.
            Included is the cylinder for reference.
            Regards,
            Marty
            cylinder.skp
            • Chris FullmerC Offline
              I wrote a plugin that finds the centerpoint of a circle once SU has "forgotten" it was a circle. You just select 2 of the edges and run the plugin and it adds a construction point to the center. It is called "Exploded Arc CEnterpoint Finder"
              http://forums.sketchucation.com/viewtopic.php?f=323&t=18963
              Hope it helps,
              • Jean LemireJ Offline
                Jean Lemire
                Hi folks.
                If you use the built in Utilities Extension that allows you to place a center point, you can place it on the circle before using the "Follow me" Tool. Then, even if the circle is exploded, the centerpoint will be there to help you align things.
                If you have already done the "Follow me", you can add a center point using these steps:
                1 - Draw a diameter between two endpoints on the exploded circle. This will close a face and gives you a line.
                2 - Using the face to position a circle and the midpoint of the line to place the center of the circle, you add a small circle of any diameter.
                3 - Use the "point at center" feature.
                4 - Delete the circle, the line and the face if need be. The construction point will remain for you to use.
                Just ideas.
                  Marty
                  All,
                  I tried the plugin from Chris Fullmer. It seems to work well. It even found the theoretical center of 2 line segments that I drew. I'm thinking that could come in useful sometime. Very nice. I'm amazed that functionality like this is not part of the core product.
                  I will also try to remember adding construction points to circles as soon as I add them. However, I tend to built models with a lot of circular sections (piping systems). The construction points are not tied to the arcs/circles they relate to so I am worried that I'll end up with a lot of construction points whose meaning I find hard to discern (probably an overblown concern).
                  Regards,
                  Marty
                    There is the same in the Thomthom Guide Tools' plug ๐Ÿ˜‰
                      Marty
                      I tried the ThomThom Guide Tools. The "CPoint at Exploded Arc Center" did not work. Not sure if I did something wrong on the install since it is a bit more complicated. I am running Sketchup 7, installed the TT_Lib2 folder and the tt_guide_tools.rb file. The tools show up in the menu but nothing happens when I click on the Exploded Arc CPoint option (above) except that the segments are deselected.
                      Regards,
                      Marty
                        Normal use is click some arc segments of ruins of circle then call the Plug
