    Cabinet Design program for Sketchup
    extensions
    52 Posts 16 Posters 28.5k Views 16 Watching
    • utilerU Offline
      utiler
      @krisidious said:
      I worked in a cabinet shop here in America for 3 years.... and I have to say they are moving toward European methods and measurements.
      That's good to hear, Kris.... hopefully we'll all be working off the same units....
      Just Curious...
      • utilerU Offline
        utiler
        I have developed a Cabinet Design program for Sketchup which may be of interest to this forum. You can watch a preview of the software at http://www.youtube.com/watch?v=763bsw5Y0Gk - your comments would be appreciated.
        Paul
        Hi Paul, so do you expect to release this plugin?
        Just Curious...
          palo
          Hi Andrew,
          I do plan to release the plugin but have no fixed date as to when that will be. A lot depends on how much time I can take away from cabinet building, but my goal is to have it ready within the next few months.
          I have been using the software in my business for the past year and am satisfied with the stability of it. It does what I need, but question whether it can handle the requirements of others. One of the purposes of this thread is to gather any reactions that could improve the product before release.
          My next step is to start producing a series of product how-to videos that I hope will generate further discussion and awareness.
          Your comments are always welcome. Please keep checking back for further discussions and video announcements.
          Paul
          • W Offline
            watkins
            Have you seen this?
            404 Not Found
            (tomatoes.ch)
            Kind regards,
            Bob
              palo
              Hi Bob, I did take a look at the tomatoes plugin last year and took another look this morning to see if the concept was still the same - which it appears to be. It lets you easily create cabinets, but lacks the ability to modify the dimensions or contents afterwards - that's a task that you do on your own or through another tool like FredoScale. I think that on smaller projects, tomatoes could be a good tool to use. I'm not sure how effective it would be on a large scale project where changeseems to be the one constant.
              With my components, you can alter all parameters after the fact - add a drawer; change doors/drawer fronts, counts, and reveals; if you change the type of drawer slide used, the drawer box size will recalculate automatically; change material thickness and all affected components are adjusted for you... You can create a model cabinet based on how you build and then store that in your components list. Once it is in that list, you can use it over and over again without having to do any work other than specifying its width - In that respect it is similar to tomatoes.
              Paul
                dedmin
                How do You handle different sizes of the same cabinet - I mean the names. Say we insert cabinet A, then another copy of the same cabinet A, but this time change the dimensions and put a different door. In the final cutlist how we gonna know which parts belong to winch cabinet? Now I'm making the copies unique and use this naming conventions - cab_part#1, for the copy cab_1_part#1
                • W Offline
                  watkins
                  Dear Paul,
                  If you could ensure that your design software applies equally to EU/UK and USA standards, then I'm sure it would be well received. In that respect, Tomatoes might be helpful in gauging the degree of conformity with EU standards. The versatility of your software should appeal to the professional kitchen cabinet designer.
                  Kind regards,
                  Bob
                    palo
                    That's a very good point Bob, thank-you, I will look at it again from that perspective. I think you hit the nail on the head regarding your comment about meeting different standards, it is one of my top concerns.
                    Paul
                      palo
                      Hi dedmin,
                      The solution I'm currently using is to have the export program make each cabinet unique. The sub-assembly in the cutlist plus export will contain the unique cabinet reference name (EG. Cabinet(1)). The part that I don't like about doing it this way, is that there is no direct tie-back to the sketchup model.
                      Paul
                        dedmin
                        Yes, that is one of the problems with dynamic components.
                          dedmin
                          @watkins said:
                          Have you seen this?
                          404 Not Found
                          (tomatoes.ch)
                          Kind regards,
                          Bob
                          This plugin creates only groups with strange names, a lot of reversed faces and the export doesn't group the parts, nor determines width, height and thickness. Not practical at all.
                            Jim
                            It is possible to have an attribute that is dynamic and uses dimensions/values directly from the model to create the name or attribute.
                              dedmin
                              I didn't know that. But what happens to the internal links between nested components? As the position of the shelf is linked to the side and the like?
                                Jim
                                I'm not sure what happens with the internal links, but I think there are 2 names for a component. One being the SketchUp definition name, the other being the DC name. In the following image, the Component Info name is dynamic while the name used internally remains "Shell". This way, the generated name can be used for reporting.
                                Here is an example of a cabinet whose name is created from the dimensions:
                                Error 404 (Not Found)!!1
                                (sketchup.google.com)
                                And it's name formula:
                                =concatenate(if(Type=30.5,"B",if(Type=28.5,"A",if(Type=26.5,"V","D"))),"27P2",if(Shallow_Depth=23.75," ","S"),if(aWidth<>27," (modified width "," "),if(aWidth<>27,aWidth," "),if(aWidth<>27,")"," "))
                                  dedmin
                                  Thanks, Jim. Yes, when the option change, it creates a new component but the names are so messy! Needs a further investigation.
                                    palo
                                    Thanks Jim. I use the component info name when I export the cutlist data. I had been searching for a way of getting a unique cabinet number to attach to the name when the DC gets created. I was hoping to reference some external component (like a project file DC), but haven't had any luck figuring out how to do so.
                                    Maybe the solution to this problem lies somewhere between your thoughts and what I'm doing currently (creating the unique name for export purposes only). Maybe I should be actually updatingthe cabinet DC's via a ruby script and generating a unique name at that time. It could be an option when the export is being generated. If the option is ignored, the system would still generate the unique numbers for reporting, but would not update the model. I think that's an acceptable workaround. thoughts?
                                    Paul
                                      dedmin
                                      I think the names of the parts in the model and in the report should match. If we have a shop drawing with labels showing the parts, and a labeled parts already sawed and they differ? It will be confusing at least. This is very important here - because this melamine boards look so identical!It is not like real woodworking - when You see a leg, You know it is a leg! πŸ˜„
                                        palo
                                        I have put a new video up today. As always any comments and recommendations would be most appreciated.
                                          dedmin
                                          Palo, see this demo videos - http://www.youtube.com/user/bazissoft#p/u
                                          This is a Russian program for furniture design - it shows the way we are working here.
                                            palo
                                            Thanks for the link dedmin. The features demonstrated in the videos would make good additions to the software and I think it would make sense to plan for some of these in future versions.
                                            The two main features that I liked were:
                                            1. Architecural line drawings. These kind of documents are crucial if you are bidding on commercial work... as well as for forming the final specifications of any contract. At this time, I rely on Layout to provide this capability, but I would love to have this done automatically for me.
                                            2. joinery hardware and placements. My software assumes that the cabinet builder will use their own methods for determining this (jigs, measurements, build notes, knowledge...). Programatically, it presents some challenges to try and implement this within the current feature set of dynamic components. A few months back, I submitted an enhancement request to the Sketchup team that would make this a relatively simple matter... I'm hoping that the level of complexity for SU to provide the feature won't be prohibitive and that it might fit strategicaly for growing their product.
                                            What were the things that interested you the most, and which ones do you think are critical for the initial release?
                                            My goal for the initial software release has been to provide a basic product that can design/layout cabinets and whose generated cutlist can be trusted regarding material, dimensions, grain orientation and banding. All placements and methods of joinery (dowels, biscuits, RTA fasteners) would be outside this domain. Perhaps my scope is too limited to make a good first release... it would be interesting to hear the viewpoints of others.
                                            For those interested in my videos, I have done 3 to-date and plan more for the future. Please check my channel (http://www.youtube.com/user/CabinetSense?feature=mhsn) from time to time.
                                            And as always, I welcome everyone's comments and views.
                                            Paul
                                            • 2 / 3
