    Clear rotation gui --?
    10 Posts 5 Posters 1.0k Views 5 Watching
      agamemnus
      I generally have a lot of trouble rotating things in Sketchup -- a really basic thing -- I can't get the right protractor to show up, and if I do it's .. sketchy .. keeps changing protractors. The Boundingbox plugin does help, but it's not ideal.
      Am I alone in my troubles..? 😢
      Today, I saw a rotation screen for a plugin that looked like a compass. I can't find it anymore... It would be great if someone could make a stand-alone thing. Not exactly sure how it worked, but I figure something like three draggable bands with markers, each controlling one axis could work...? 💭
      • mitcorbM Offline
        mitcorb
        As you know, the rotate protractor turns the color of the axis it is aligned with. If it is not on the orthogonal it is just black. And as you know you can hold down the Shift key to lock its orientation and place the rotate protractor on say a particular vertex or edge or face whether it is a particular color or black.
        Once in position you can then click on the geometry, and swing the protractor through a desired angle. If you do not like the angle shown in the VCB or whatever the little value box is called these days you can type in the desired value and hit Enter and the rotation will adjust to that value.
        In order to get the right protractor to show up you may have to orbit till the camera is pointed at the model and more or less parallel to one of the axes and the ground. It shows up readily in the sky when viewing parallel to the ground. Use the Q key to activate the protractor or click the toolbar button.
        I am not sure if when you reset the axes to something other than global if the colored protractors show up. 😒
        I hope this can help you.
        • Chris FullmerC Offline
          What do you mean you can't get the right protractor to show up? The correct color?
            boundingbox plugin? in relationship with rotating?
            Is it SketcHups native rotation tool you refer to? http://sketchup.google.com/support/bin/answer.py?answer=94894
            I am working on such a gizmo for some of my plugins. Could port it to a general tool. ...but I think there might be one already.
              Here's a plugin that gives you a manipulator gizmo: http://forums.sketchucation.com/viewtopic.php?t=20346
              nearly identical to what I'm working on.
              • mitcorbM Offline
                mitcorb
                @ThomThom: I think your last reply was what agamemnus might be looking for.
                  agamemnus
                  Thanks. I forget all those hard to find keyboard commands.. Also: Interesting tip about rotating towards the sky, but all that machination just seems like some sort of secret combo in a Sega video game instead of a legitimate method. 😉
                  Yes.
                  thomthom:
                  That's not the one I am referring to, but I'll check what wikii made. I don't like that the gizmos rotate with the object, though.
                  • mitcorbM Offline
                    mitcorb
                    I sort of understand your point about the Sega video game reference, but what I told you was partly from my search for official instructions and partly from discovery about orbiting and rotating--sort of developing a working knowledge. But this technique is a more "close to the hand" technique deliberately designed into the Sketchup application.
                    Did that make any sense?
                      agamemnus
                      Yes, but it would have worked better if there was some sort of info box or something similar that popped up which gave me the keyboard-only features for the particular function I was using.
                      • jason_marantoJ Offline
                        jason_maranto
                        It's called the instructor -- you can launch it from the windows menu. It doesn't have all the keyboard shortcuts but most of them.
                        Best,
                        Jason.
