    Jpg textures in *.skp
    34 Posts 5 Posters 4.7k Views 5 Watching
      Yea - occasionally texture filenames doesn't have a path. The ones that bundle with SU never does.
        soldatino
        yes, this is now the way that I use to find the pointer of the jpg end.
        DefStr endj
        DefStr endjH
        endj="."+chr$(0)+"j"+chr$(0)+"p"+chr$(0)+"g"+chr$(0)
        endjH="."+chr$(0)+"J"+chr$(0)+"P"+chr$(0)+"G"+chr$(0)
        DefStr slash1$ ; slash1$=chr$(0)+"/"+chr$(0)
        DefStr slash2$ ; slash2$=chr$(0)+"\"+chr$(0)
        DefStr slash3$ ; slash3$=chr$(&hFF)+chr$(&hFE)
        then, looping block of 200 bytes, then, if the block has endj or endjH then, looping in the block
            hh$=File.ReadBinStr(1) ; rd=rd+1
            File1.WriteBinStr(hh$,1)
            if hh$="." then
              DoEvents
              npo=File.position
              hh$=File.ReadBinStr(6) ; File.Seek(File.Position-6,0)
              chh=REPLACESUBSTR$(hh$,CHR$(0),"")
              chh=LCASE$(chh)
              DoEvents
              IF chh="jpg" then
                File.Seek(File.Position-128,0)
                name$=File.ReadBinStr(134)
                slash1=INSTR(name$,slash1$)
                slash2=INSTR(name$,slash2$)
                slash3=INSTR(name$,slash3$)
                IF (slash1 + slash2 + slash3)<>0 THEN
                   >>>  FOUND! Then I start the detailed search of the pointer...
        and now I am waiting for the next file that will fail πŸ˜•
        r3nDer tools
          Are you sniffing out the image size instead of reading the integer in front of the image data?
              soldatino
              I did not attempt to sniff the jpg size because the compress header has particularity different of other picture formats, it is not a true header, and I dont have enough knowledge about it.
              But your screeen shot is very good. I only knew the FF+FE recurrence. Your confirmation is important for me, with your addictionally info also.
              ps I now can improve the exact png filename also, that at this moment I did not still search...
              r3nDer tools
                What header are you referring to?
                I'm not sure if we are referring to the same thing - maybe this screenshot will help.
                  Did you look at the text file I attached earlier? with notes on the format.
                  SketchUp File Format
                  Reverse Engineering Attempt by Thomas Thomassen
                  [thomas@thomthom.net]
                  /// BLOCKS /////////////////////////////////////////////////////////////////////
                  There are reoccuring patterns. Looks like block signatures.
                  Blocks Signature; FF FE FF ??
                  The next byte gives the size of the block (or block name)
                  If the UBYTE after the signature is not NULL then it appears to be a UTF-16LE
                  string. UTF-16LE string signature? Many places there is no string, the ?? byte
                  is just NULL.
                  Some places (FF FF) indicates a new section or area. Bytes before that mark
                  might be important. For the Material and Layer section there is four bytes with
                  the total number of Materials and Layers.
                  (FF FF) appear to be preseeded by four bytes. ID number/signature?
                  Apart from the byte indicating the Unicode string there doesn't seem to be any
                  bytes that indicates the size of the blocks. Looks like it's required to know
                  the structure to read the file. Even just part of it.
                  Due to plugins there could be extra information and blocks inserted.
                  Components also complicates things as they appear as files within the file. Due
                  to this you can not blindly scan for strings or byte sequences.
                  What is the pattern to the file structure?
                  How do you scan/skip to the interesting data reliably?
                  /// THEORY /////////////////////////////////////////////////////////////////////
                  Blocks (Sections);
                  2 bytes - Signature (FF FF)
                  2 bytes - (Short) Block ID or VersionMap referance
                  2 bytes - (Short) Size of Block Name
                  ? bytes (Size of Block Name) - Name of Block (ASCII)
                  FF FE FF Signature indicates Sub-Blocks. (Blocks inside the sections)
                  TIME_T - 32-bit value representing date and time in C using the format
                           'MM/dd/yyyy hh;mm;ss'. time_t is a 32-bit integer representing the
                  		 number of seconds since 01/01/1970 12;00 AM.
                  /// HEADER BLOCKS //////////////////////////////////////////////////////////////
                  /// SkechUp File ID ////////////////////////////////////////////////////////////
                  | 3 bytes - Block Signature (FF FE FF)
                  | 1 byte - Block Name Size (in characters)
                  | 28 bytes (14 Unicode Characters) - 'SketchUp Model'
                  /// Version Number /////////////////////////////////////////////////////////////
                  | Variable Bytes (Block Name Size) - Version Number wrapped in curly brackets
                  | 16 Bytes - ? (Random every time, even when doing a Save As)
                  |   When doing a Save As the files should be identical, but this section of data
                  |   differs anyway. (Tested with a file doing Save As two times. Result was
                  |   three files with the same size but had differences in two areas of this data
                  |   chunk.
                  /// Time Stamp /////////////////////////////////////////////////////////////////
                  | 1 byte  - Block Name Size (00)
                  | 4 bytes - Timestamp of when file was saved. Appears to be UTC regardless of
                  |           locale. (TIME_T)
                  /// VERSION MAP ////////////////////////////////////////////////////////////////
                  | 6 bytes - Section Sig (FF FF 00 00 0B 00)
                  | 11 bytes - 'CVersionMap'
                  ~~~ Repeat ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                  | Variable Bytes (Block Name Size) - Name of Capability
                  | 2 bytes - ? (Capability ID?) Relates to Short Int after Blocks.
                  | 2 bytes - ?
                  | 36 Bytes (18 Unicode Characters) - 'End-Of-Version-Map'
                  /// Unknown Data ///////////////////////////////////////////////////////////////
                  | 16 Bytes - ?
                  |    00 00 00 00 01 00 00 00 B0 04 00 00
                  | !  01 or 03
                  |    00 00 00
                  |     Theory; 4 Ints
                  |     4 bytes - ? (00 00 00 00) Unsigned Int; 0
                  |     4 bytes - ? (01 00 00 00) Unsigned Int; 1
                  |     4 bytes - ? (B0 04 00 00) Unsigned Int; 1200
                  |     4 bytes - ? (03 00 00 00) Unsigned Int; 3 OR (01 00 00 00)
                  /// CDib Block /////////////////////////////////////////////////////////////////
                  | 6 bytes - Section Sig (FF FF 03 00 04 00)
                  | 4 bytes - 'CDib'
                  | 4 bytes - ? (04 00 00 00)
                  | 4 bytes - Unsigned Int - Size of Image Data (PNG file)
                  | {PNG DATA}
                  | 10 bytes - ? (01 00 00 00 00 00 00 00 00 00)
                  /// Camera /////////////////////////////////////////////////////////////////////
                  | 6 bytes - Section Sig (FF FF 05 00 07 00)
                  | 4 bytes - 'CCamera'
                  | 139 bytes - ?
                  | 236 bytes - ? (!) Does not match for .skp files with V-Ray material
                  /// Materials //////////////////////////////////////////////////////////////////
                  | 4 bytes - Material Count
                  | 6 bytes - Section Sig (FF FF 0C 00 09 00)
                  | 9 bytes - 'CMaterial'
                  | 2 bytes - ? (00 00) Or other data if the material has an attribute attached.
                  ~~~ Repeat by number of Material Count ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                  /// Material Block /////////////////////////////////////////////////////////////
                  | Variable Bytes (Block Name Size) - Material Name
                  | 1 byte - ?
                  | 1 byte - ?
                  | 1 byte - Red
                  | 1 byte - Green
                  | 1 byte - Blue
                  | 1 byte - Alpha
                  /// Unknown ////////////////////////////////////////////////////////////////////
                  | EMPTY
                  | 21 bytes - Unknown
                  /// Layers /////////////////////////////////////////////////////////////////////
                  | 4 bytes - Layer Count
                  | 6 bytes - Section Sig (FF FF 02 00 06 00)
                  | 6 bytes - 'CLayer'
                  | 2 bytes - ? (00 00)
                  ~~~ Repeat by number of Layer Count ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                  /// Layer Block ////////////////////////////////////////////////////////////////
                  | Variable Bytes (Block Name Size) - Layer Name
                  | 1 byte - Visibility (00 or 01)
                  | 1 byte - ?
                  | 1 byte - ?
                  | REF; Material Block
                  |      Material block name; Layer_{Layer Name}
                  | 4 bytes - ? Extra bytes trailing the Layer Material Blocks.
                  | EMPTY
                  | 6 bytes - ? (0C 00 00 00 00)
                  | 4 bytes - CEdge Count? (Unlikely. Return 18 on model with 12 edges)
                  | 2 bytes - ? (FF FF)
                  | 4 bytes - ? (02 00 05 00)
                  | 5 bytes - 'CEdge'
                    soldatino
                    Yes I downloaded it but I did not found jpg blocks and I thought that the markers was the signature only for the structures of objects and the jpgs were an unexplored different attachment.
                    Addictionally I thought that SU maintained an area of overwriting for the jpg images in the file, because I find garbage (jpg started and not ended, but it is possible that I was wrong) and I got the idea of a single physical space of storage...
                    r3nDer tools
                      soldatino
                      [attachment=0:3ag13v96]<!-- ia0 -->SUMaterialStart.png<!-- ia0 -->[/attachment:3ag13v96]
                      exactly I was talking of the header of the jpg file itself
                      updated 0.0.9
                      faster, filename's search uses only ("jpg" or "IEND" strings) + &FF&FE&FF pointer
                      r3nDer tools
                        soldatino
                        Well I need win API in SU's Ruby because I want write a rb plugin with the same code I use in T-Magnifier, but it seems that I cannot without complicated extensions ! 😲
                        All the languages can access to the win API...
                        r3nDer tools
                          You can use Win32 API...
                          http://ruby-doc.org/docs/ProgrammingRuby/html/lib_windows.html
                            soldatino
                            thanks but the meaning of the error vs
                            require 'Win32API'
                            is that the build-in Ruby in SU does not have this extension? Does the user need to install ruby runtime components?
                            r3nDer tools
                              one need a win32api.so file - there are some SU plugins that already ship with this. It's the only file you need to bundle.
                                soldatino
                                thanks , I now see that about it there are topics in the forum...
                                r3nDer tools
                                • 2 / 2
