    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    VMV - plugins
    6 Posts 3 Posters 974 Views 3 Watching
      DIEGO-RODRIGUEZ
      Someone knows this compilation of plugins?
      http://www.vmv-cad.nl/site/support/sketchupinstructie.html
      [flash=853,505:hd67khbv]http://www.youtube.com/v/PnH1ba3_nx8&fs=1[/flash:hd67khbv]
      [flash=853,505:hd67khbv]http://www.youtube.com/v/cY82y6KAiVk&fs=1[/flash:hd67khbv]
      The first video shows a very interesting feature. Adjust the toolbars without having to close and open sketchup
      The second video shows another interesting feature. Generates holes in the walls to the shapes of the components with a single click
      possible, get these plugins?
      • Didier BurD Offline
        Didier Bur
        In their toolbars, they include JPP and Selector ? I don't know if Fredo and Jim are aware of that ?
        Concerning the second feature, I wrote something similar some time ago: Cutting windows, the script can be downloaded here:
        http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=98
        I don't know if the VMV script can drill holes other than rectangular, mine can BTW, and you can also control the location of the component within the wall thickness.
        Hope this helps,
        DB
          DIEGO-RODRIGUEZ
          Thanks, Didier. but in sketchup 8 generate this error.
          Error al cargar archivo cutting_windows.rb
          (eval):719: compile error
          (eval):610: syntax error, unexpected ',', expecting kEND
          faces_and_heights[0].pushpull (faces_and_heights[1]), false
          may correct this error?
          I do not know if Fred and tig are aware of the improper use of the plugins
            Didier Bur
            Hi Diego,
            Try the attached rbs (overwrite your old rb) and tell me if it works, especialy in SU8.
            I'll update the script if it works.
            Regards
            cutting_windows.zip
            DB
              DIEGO-RODRIGUEZ
              didier, thanks for responding.
              now generates an error and it works.
              but I think it works well, inner and auter face of wall.
              although it can also happen that I do not understand how they work, ๐Ÿ˜„
              [flash=853,505:15kqgi3p]http://www.youtube.com/v/2qUqbobLyUw&fs=1[/flash:15kqgi3p]
              may be added, optional smoothing+aliasing
              • fredo6F Offline
                I was not aware.
                But as I don't understand Dutch, it is not clear to me whether JPP is part of the VMV delivery, or just there as an example of the toolbar customization.
                If someone from Holland can translate, this would help.
