    How Do I Copy Camera Positions To Other Models
    3 Posts 3 Posters 1.4k Views 3 Watching
    • Z Offline
      zachs
      Does anyone know how I can copy camera views from one model to another. I am trying to export the same veiw of multiple concept models. They all share the same relative coordiantes. Is there a way to copy the views from one to another? A script or some feature in sketchup?
        Hi Zachs,
        There is one at Smustard: PageExIm (i.e. Page export-import - scenes used to be called pages in SU 5 and prior). It's a $5 commercial plugin however.
          There are a couple of things you could do without a plugin, though. You could delete the entities in the first model (and purge the unused components) but leave the secens as they are. Save the results as a new file. Then copy the second model into this saved file. Presto!
          If both models share stuff like background or have common parts, you could associate a layer with "version 1" and another layer with "version 2" in the same SketchUp file. Leave the things that would show in both versions on a third layer or Layer 0. Then go to each of your existing scenes and swap version 1 for version 2. Create new scenes for the version 2 views. After you've completed that, you can reorganize the scenes so all the version 1 scenes are together and all hte version 2 scenes are together.
          Takes longer to write about than to do.
