    Wrinkle paint
    30 Posts 5 Posters 4.8k Views 5 Watching
      Roger
      I am modeling an old motion picture camera and can not find a good wrinkle paint texture. Can anyone recommend a source. I don't want to tile so I need a 10"x10" sample.
      Thanks -
      http://www.azcreative.com
      • soloS Offline
        Roger, are you planning to render it?
        The reason is then you can use a procedural bump, it's hard to find a photo texture as the wrinkles react with light and shadow for real effect.
          Roger
          Is "procedural bump" and "bump map" the same thing?
          I was planning using a flatly lit texture photo on top of a bump map made from the same photo.
          • W Offline
            watkins
            Dear Roger,
            Is the attached of any use?
            Dull Casting.skm
              Roger
              @watkins said:
              Dear Roger,
              Watkins, I appreciate the help and will find a use for that texture, but what I am looking for is more like a bucket of humping worms when seen up close.
              • W Offline
                watkins
                Are these of any use?
                New Folder.zip
                  Roger
                  The red one turned out to be excellent once I changed the color. So for the best result I should use a flat color and use the texture to build a bump map?
                  • W Offline
                    watkins
                    Glad you found one texture useful.
                    Regards,
                    Bob
                      Roger
                      Bob let me know if you ever need a texture or scene you can not find and I will shoot it for you if I have the material available. Gratis.
                        Roger, at CGTextures, on the left bottom, there is a whole library of different wrinkles you may use to start with.
                          Roger
                          Great resource, Thanks Gaius.
                            Roger
                            A work in progress as I learn how to work with twilight render
                            A test of the wrinkle paint. Many small parts still to be created and attached to the camera.
                              Roger, that looks like a cool project. What kind (make, model) of camera is it? I remember that paint finish on many old movie cameras and projectors. Durable stuff.
                                Roger
                                It is a 16mm Bell and Howell Filmo (D70) which is the little brother to the 35mm Bell and Howell Eyemo. They were standard issue for Army motion picture photographers in WWII, Korea and Vietnam. I used this kind of camera to film Special Forces operations in Vietnam and clips from my footage were used in episodes of the History Channel's Suicide Missions Series (MACV/SOG Vietnam and Mike Force)and Discovery Channel Wing's program Dustoff: Helicopter Ambulance Operations over Vietnam. The empty camera weighs seven pounds which with 10 100ft reels of film would be roughly equal to an M16 rifle with a loaded 30 round mag (8.7 pounds).
                                If push came to shove, it could also be used for close quarters combat.
                                • W Offline
                                  watkins
                                  Does anyone remember the Brownie Box Camera? I still remember my dad looking into the viewfinder and waving his hand to get us to bunch up closer. I still have the camera.
                                  Access Denied
                                  (www.brownie-camera.com)
                                  Regards,
                                  Bob
                                    Roger, I remember seeing the Filmo in the display case of old cameras at the last camera store in which I worked.
                                    Bob, I still have one of each of the two with the red arrows. The upper one belonged to my grandmother and the lower one to my mother.
                                    They are still functional but I don't think the film is available anymore. I used to have quite a collection of old cameras, many of which I used from time to time. They've nearly all been given away except those two.
                                    • W Offline
                                      watkins
                                      I have the upper one, and I keep it in memory of my happy childhood and my long departed parents. Generally, and unlike today, the camera was only used to record holiday moments (at the zoo, on the boating lake etc) as buying and developing film was considered a bit of a luxury in the 50s. There are few if any photos of birthdays, Christmas etc.
                                        When I was working in the camera stores it wasn't unusual to see the pictures from the little old ladies in which there would be two consecutive Christmases on the same roll.
                                          Roger
                                          I have some camera's that would have stories to tell if they could only talk.
                                            I'll bet.
                                            I remember selling cameras that did talk. πŸ˜†
