    [HELP] Plugin/s used best for car modeling...
    5 Posts 4 Posters 449 Views 4 Watching
      dropoyin
      guys,
      hello, i'm new in 3D modeling, i just want to know which plugin/s were use in vehicle modeling, which plugin works best?
      thanks guys, hope you can help me with that, coz there's a lot of plugins here, and i don't know which is which... 😄 thanks
      • mitcorbM Offline
        mitcorb
        Check out ely862me's postings. Maybe also converse with him. My understanding is that the car modeling process is a lot of knitting. He may also use some plugins in the process. Probably Subdivide and Smooth, which is a retail plugin.
        TIG's Extrude Tools set is capable.
        Fredo's Curviloft can do it.
        More importantly, you have to go through the learning curve, whether you do everything from scratch or with plugins, and depending on how well you learn, the time curve can be fairly short, or excruciatingly long.
        I am certainly not trying to scare you away, as the learning can be very rewarding- at least it is for me on a personal level.
        I stop babbling now.
        • EscapeArtistE Offline
          EscapeArtist
          +1 for Mitcorb's suggestions.
          I would personally try to avoid SD&S as it can have unwanted results as far as size and shape changes that can affect the fit of car panels, but there's no reason not to give it a try.
          Definitely Curviloft, JPP and the Extrude Tool set.
            d12dozr
            Fredo's Bezier plugin will certainly help as well.
            http://goo.gl/f7ooYh
              dropoyin
              thanks guys, i really appreciate your suggestions... for me if they can do it, why can't i? 😄 i will just give it a try... thanks guys.
