    Selecting All Visible Faces
    17 Posts 5 Posters 6.7k Views 5 Watching
      I'm not aware of any..
      • K
        kwalkerman
        I'm not sure what your end goal is here, but with SU pro, you can export as a 2D drawing into all kinds of formats, DWG included, which will show you only the current view.
        It would be nice if the camera object had an "all_visible" function... but as far as I know, it doesn't. The only way I know to find objects that are visible, is to do model.raytest, which is time consuming, and only tests one ray at a time.
        Karen
          And another problem with raytest is what points to test? testing just vertices isn't enough, they could all be hidden from the camera, but a part of the surface might be visible.
          • Chris FullmerC
            I just wrote a test code that run pickhelper on every x,y of the screen and adds everything it hits to the selection.
            It worked ok. Biggest problems are that it can miss tiny faces (though it was a LOT better than I thought it would be) and even worse - it was over-zealous. It added things that were definitely not visible.
            But I'd say it was about 80% good. You can play with it here:
            WARNING: This is EXTREMELY slow. Minimize your window to a large thumbnail size view if you just want to quickly test this. Full size window takes easily over an hour to process I think.
            view = Sketchup.active_model.active_view
            Sketchup.active_model.selection.clear
            w = view.vpwidth
            h = view.vpheight
            w.times do |x|
              h.times do |y|
                ph = view.pick_helper
                ph.do_pick x,y
                t = ph.all_picked
                t.each do |ent|
                  if (ent.is_a? Sketchup;;Face) or (ent.is_a? Sketchup;;Edge)
                    Sketchup.active_model.selection.add ent
              The pick_helper has an aperture, have you tried adjusting that and see if you get different results?
              • Chris FullmerC
                No, I did not play with it at all....might be intersting.
                I think the reason it over actively picks things is at least 2 fold. 1 - I am adding all picked ents (as opposed to best_picked, which I think you hit an edge of a face that is not visible, it returns the face anyhow. 2 - it seems to pick right through close faces. So if a hidden face is clse to the front face, I think it wll pick right through the front face, much like z-fighting.
                • honoluludesktopH
                  honoluludesktop
                  Hi Chris, That's a neat snippet.
                  • Chris FullmerC
                    Thanks, it would be a lot cooler if it was fast and accurate πŸ˜„ I would like to play with the aperture size. Maybe that would help speed things up? What if the aperture could be sut to the height and width of the monitor, and then just run a single "pick" and choose all selected. I'll try to play with it when I get a chance, unless someone beats me to it.
                      I was thinking that the aperture was why you got entities not really visible,,, πŸ˜•
                      • honoluludesktopH
                        honoluludesktop
                        Chris, I used your scanning engine in this plugin. It adjust the fov to decrease the scanning time, but it is still slow. However it will help me port, and correctly face my Cad models for visualization in Sketchup. Thanks.
                        The attached images are of a model that contains a total of 2,000 edges and 650 faces. It took about 45 seconds to check the view and reverse the back faces.
                        Test model with front and back faces.
                        Test model with back faces reversed in model view.
                        • G
                          gude
                          Chris's method along with 'deselect faces that have normals away from camera'
                          will do the task,
                          What if,
                          Just to filter the occluded faces.
                          but might be elementary
                          Is it feasible to project random points from planes in the camera.direction to test if the points do project on other planes?
                          Would it be taking too much to calculate?
                          this filter might include the partially visible ones any ways.
                          • G
                            gude
                            I couldnt understand the way they did it here
                            http://forums.cgsociety.org/archive/index.php/t-197347.html
                              That is the method I mentioned earlier - it selects the faces which normal is pointing towards the camera - but it doesn't take into account other faces blocking the view.
