    How do i call subroutine in animation / onclick?
    Scheduled Pinned Locked Moved Dynamic Components
    3 Posts 1 Posters 1.6k Views 1 Watching
      skyfish
      I have a component which rolls on a track. I have been using a formula for intersection of line-circle and line-line to change the component coords at each increment of the animation in Sketchup Pro 7. Works great.
      The formula's are in the enclosing component which holds the sub-components like wheels,track etc.
      With onclick I calculate the coords with every increment of the animation. Unfortunately I have separate intersection calculations for each sub-component and it is getting messy.
      I would like to implement something like Line_Line_intersect(ParmIN, ParmOUT) & Line_Circle_Intersect(ParmIN,ParmOUT) which I would call in my IF().. statement.
      I scanned ruby but it is not clear to me that this is possible. Surprised I couldn't find a clear answer to this anywhere.
      skyfish
        skyfish
        I restructured the code and changed the algorithm. Now I can create rolling elements by
        • copying typical component
        • make unique
        • renaming
        • change offset
        If you would like to see example, I have attached a file.
        skyfish
        EDIT:
        Oops, now I remember the problem with this algorithm. The
        distance between balls is a measure of the curved path. It
        doesn't maintain a rigid connection between balls. Going
        around the curve, the inter-distance is slightly small.
        trackroller.skp
          skyfish
          Since I am not getting any replies about subroutines, I did restructure again so that I can copy DC and make a few changes to produce a component that maintains distances.
          The example would work for a garage door ( using ASIN & ACOS for angles ).
          The calculations were adapted from
          http://local.wasp.uwa.edu.au/~pbourke/geometry/sphereline/
          http://local.wasp.uwa.edu.au/~pbourke/geometry/2circle/
          There are some weird bugs in sketchup when using large numbers, in addition to the SQRT problems.
          skyfish
          trackroller II.skp
