    EPS Export Problem
    2 Posts 2 Posters 548 Views 2 Watching
    • L
      Lasseman
      What is wrong with this file ?
      This file 003.skp do not work to exported as EPS (want to import to CorelDraw)
      The exported *.eps is only 1kb (strange)
      Usually it works with same settings for other *.skp files.
      File (003.skp) should be attached
      SKP file with no EPS export
      • AnssiA
        Anssi
        Your model lies quite far from the SU model origin point (more than 2 kilometers). As it is, a scaled export from a plan view worked OK, but the unscaled perspective view didn't. When I moved the model to the origin it worked OK.
        Anssi
