    Assistance with a massive project
    20 Posts 5 Posters 2.1k Views 5 Watching
    • soloS
      I believe that Sketchyphysics and Twilight will be the easiest solution (if you know Sketchyphysics that is). AFAIK Twilight is the easiest way to render an animation using SP, properanimation.rb as well as mover.rb.
      • TK0001T
        TK0001
        Thanks for the words of wisdom. Encouraging to know that Podium will probably be a good choice.
        I do have my models pretty well component-ized, so hopefully assigning materials to them won't be too much of a task. I can stick with just using colors rather than textures for nearly the duration of this project, as the purpose of the project is to pretty much use SketchUp as a BIM tool to find interferences across the assorted phases. At the end of the project they'll be asking for a rendered picture to be plotted out and framed. I'm pretty excited to see how that will look.
        They will also ask for a box animation and a forklift animation, but both include the manipulation of the static model, so I'll just need to find something that will allow me to make a camera path throughout the system and not actually make boxes zip around it. I have played around with Sketchyphysics a bit, but I think animating tens of thousands of boxes on the system with it would be a nightmare.
        • GaieusG
          Well, be careful with that "plotted" render. You may bounce into image size limitations due to SU being a 32 bit app and using limited memory.
          You can get out about a 4000x3000 pixel rendered image however that would be 40 inch wide (~1m) at 100 dpi (on the wall, I believe you would not need 300 dpi).
          MAYBE if only using colours, it can be a bit bigger, too. If you use Twilight as Pete suggested and export the XML, that can be opened in Thea as well and it has a 64 bit version, too, which of course could export bigger.
          • TK0001T
            TK0001
            Excellent advice, thanks. Never considered the fact that SU is 32 bit.
            I do believe that they'll want a 24 x 36 plot of the system, but I would love to see it be 36 x 48 and properly matted and framed.
            So in light of this, would you suggest going with Twilight rather than Podium?
            • GaieusG
              BOTH Twiight and Podium are integrated into SU therefore have the memory limitation.
              I do not suggest either (in fact, I should be unbiased here as an admin 😒 ), only Pete's idea made me think.
              You can download and install the trial version of both and with some limitations (this mainly means size limit at export), can test both. They both have quite competitive prices, too.
              • TK0001T
                TK0001
                Ah, understood.
                I have downloaded the trial version of Podium and have tinkered with it, thus my leanings toward it. But before taking on this task (if I'm fortunate enough to win the job), I need to know if there exists software that can do what I need within SketchUp so that I can complete the entire job and not just 99% of it. So I ask the experts who have more applicable experience with the rendering software in question.
                • GaieusG
                  Well, I am sure you can finish the job with SU. Having seen your other models, this one does not really look like much different.
                  Since your later render does not necessarily include difficult texturing ("just" - or mostly - some shiny paints), I am sure it won't be too hard to achieve the results either.
                  • TK0001T
                    TK0001
                    This is a relief to hear. Thanks very much for the assistance.
                    Yes, the texturing will almost entirely consist of shiny paints. That's primarily why I haven't bothered with texturing and rendering up to this point. This is an industrial application, so there's no need to get complicated with texturing.
                    Although I still can't wait to see what it would look like textured with just paint and rendered.
                    • GaieusG
                      Then get stated and hurry up!
                      • TK0001T
                        TK0001
                        Believe you me, if I could start today I would. They just need to give me the project and I'm off!
                        • TK0001T
                          TK0001
                          Messing around with Podium, putting together the proposal. I plan on adding these images to it as a sampling of what is possible. By the way, there are no supports and everything is floating in the air. This is on purpose, since this is a functional layout, with the intent of finding interference, so supports aren't necessary. This is also why every detail hasn't been included.
                          http://img840.imageshack.us/img840/1610/portiso2.jpg
                          http://img444.imageshack.us/img444/4369/portlandlighting1.jpg
                          • mitcorbM
                            mitcorb
                            If you did those chutes yourself, you are a fast learner. That is no mean feat.
                            Impressive model.
                            • TK0001T
                              TK0001
                              Impressive model.
                              Thank you very much!
                              Yes, I did do those chutes myself. Everything in the model was created by me. Those spiraling concave chutes were by far the most challenging components I've done so far. I'm pleased with how they turned out.
                              Thanks again for the kind words.
                              • TK0001T
                                TK0001
                                Here's the other side of the building.
                                http://img230.imageshack.us/img230/1374/portlandlighting2.jpg
