    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Cube(square shape) along path script?
    10 Posts 7 Posters 866 Views 7 Watching
    • 3 Offline
      3dsketchupper
      I'm not sure if this plugin is available?
      i've been searching skp scripts but can find any.
      It is similar to Tube along path. But what i need
      is not "circular" in shape but square?
      Can somebody point me were i can find it if available.
      Thanks for your help
      • KrisidiousK Offline
        Krisidious
        followandkeep?
        curviloft also accomplishes the follow along a path for shapes.
        By: Kristoff Rand
        • honoluludesktopH Offline
          honoluludesktop
          Can't you use TIG's pipe along path and set the segments to 4?
          • 3 Offline
            3dsketchupper
            Kris: Thanks for your reply, I got fredo's script but a bit complex for me at the moment.
            Honolulu: That was a good suggestion but square profile in an angle! πŸ‘Ώ
            It will great for creating window frames i.e. in different directions.
            Cheers
              d12dozr
              Free: TIG's EEbyFace...Part of the Extrude Toolset
              $29: Profile Builder
              Does that help?
              http://goo.gl/f7ooYh
              • BoxB Online
                Perhaps I'm misunderstanding your problem, but if all you need is this, then just use follow me.
                Draw your square, draw the path you want it to follow.
                Select the path and then select the square with the Follow Me tool.
                  caleidos4d
                  ExtrudeAlongPath:
                  http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=136
                  http://www.caleidos4d.it
                    πŸ˜‰
                    You have also Line2tube by Didier Bur β˜€
                    (works for circle, arc, curves)
                    If you want "Square", just put 4 as Precision πŸ˜‰
                      caleidos4d
                      πŸ˜‰
                      [attachment=0:1hbqtdum]<!-- ia0 -->square.jpg<!-- ia0 -->[/attachment:1hbqtdum]
                      is not a square πŸ˜„ this is a quadrilater πŸ˜„ (square rotate to 45Β° )
                      • 3 Offline
                        3dsketchupper
                        Caleidos4D : Extrude along path will do. Almost similar to pipe along path ruby
                        i can use follow me but i have to create shape first πŸ˜„
                        Thank you people for your help. For sure this will make my work easier.
