Cube(square shape) along path script?
I'm not sure if this plugin is available?
i've been searching skp scripts but can find any.
It is similar to Tube along path. But what i need
is not "circular" in shape but square?
Can somebody point me were i can find it if available.Thanks for your help
followandkeep?
curviloft also accomplishes the follow along a path for shapes.
Can't you use TIG's pipe along path and set the segments to 4?
Kris: Thanks for your reply, I got fredo's script but a bit complex for me at the moment.
Honolulu: That was a good suggestion but square profile in an angle!
It will great for creating window frames i.e. in different directions.Cheers
Perhaps I'm misunderstanding your problem, but if all you need is this, then just use follow me.
Draw your square, draw the path you want it to follow.
Select the path and then select the square with the Follow Me tool.
ExtrudeAlongPath:
http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=136 -
You have also Line2tube by Didier Bur
(works for circle, arc, curves)
If you want "Square", just put 4 as Precision
[attachment=0:1hbqtdum]<!-- ia0 -->square.jpg<!-- ia0 -->[/attachment:1hbqtdum]is not a square
this is a quadrilater
(square rotate to 45Β° ) -
Caleidos4D : Extrude along path will do. Almost similar to pipe along path ruby
i can use follow me but i have to create shape first
Thank you people for your help. For sure this will make my work easier.
