    Problem to Constraint sizes to a maximum value
    Scheduled Pinned Locked Moved Dynamic Components
    2 Posts 1 Posters 1.1k Views 1 Watching
      gerard.degreve
      Hello,
      I'm trying to create a dynamic component whose length and width are limited to a maximum value, and whose thickness is fixed .
      I used the following formulas
      LenX; =SMALLEST(60, CURRENT ("LenX"))
      LenY; =SMALLEST(120, CURRENT ("LenY"))
      LenZ; = 2
      Scaling handles are limited to the X and Y axes.
      When I resize the component by using the handles or by typing a numeric value, the result is completely erratic.
      The component is always resized, and not at the size, and in different dimensions than those I imposed, even if I chose dimensions lower than allowable maximum size.
      And finally, the component is always resized on both axes, while I can only act on one axis at a time.
      I also tried another formula, with the same result:
      = IF (CURRENT ("LenX")> 60,60,CURRENT ("LenX"))
      I would be grateful if you could tell me why it does not work, or give me some tips to achieve the goal sought.
      Thank you in advance
      Gerard
        gerard.degreve
        Hello,
        I think I found where the problem lies:
        After testing many variations to my formulas, without success, I had the idea of changing the internal units of the component.
        Being Belgian, I naturally use metric units, so my component was configured with "cm".
        So I converted all numeric values in inches and reconfigured the component to use same unit.
        Miraculously, everything works now as expected 😍 , even when using the component in a model configured in metric units.
        I think there's a bug in the function CURRENT("LenX/Y/Z") which should return a value expressed in inches, whatever the choice of internal units.
        Well, I hope my experience will serve the other!
        Thank you for your attention,
        Gerard
