Tudor style house rendered in Shaderlight
Hi heres my latest render using Shaderlight. It was rendered using Shaderlights exterior lighting using a HDR image, the model was then intergrated into the backplate which was also taken at the same location as the HDR image.
Beautiful, not much more to say really!
Very impressive.
Puck
Wow, the texturing/realism is amazing. I think the only improvement I can suggest is a little weathering on the stucco.
Impressive use of a texture matched building. I assume the windows aren't modelled. Can we see a wire frame? I like it... your getting very good at these!
Very Nice Work.
Como dicen en España: ¡Hala, qué pasote!
Incredible work, textures and environment! Very nice!
Heres a screengrab of model in SU. Very simple setup as you can see here, of course some details were done in photoshop the same time model was integrated into backplate
Fantastic. I quite like the Tudor style, if I'm ever so fortunate as to build a home it would be in the Tudor style.
I'm curious about the textures though, are they pictures from a Tudor building or did you create them from scratch?
I had a single photo this house which I used as a starting point for texturing. The textures were then heavily re-worked in Photoshop to get rid of distortion, unwanted lighting information etc etc. By the end of the texturing process your pretty much left with hand painted textures, but becuase you have a good starting point its alot easier to get good final results.
Thanks for the info. Very well done.
Great job!
Keep it up.
_KN
