    4 Levels of Grouping
    17 Posts 3 Posters 3.7k Views 3 Watching
    • W Offline
      Wacov
      I feel like I'm in too deep πŸ˜„ I think it'd be a good idea if the groups returned afterwards, as they don't really matter in the simulation. I really don't know any ruby script, so good luck πŸ˜„
        CPhillips
        Its a bug. And one I didnt know of. Thanks David.
        Not sure what is causing it but I will fix for SP3.
          CPhillips
          Turns out this isn't really about group depth. It happens when a group contains only a single group.
          Group
            Group
              etc.
          Ill fix it in SP3.
            Davidfi1
            SketchyPhysics3x Jun 27
            This problem is not solved as far as I can tell
            Thank you.
            David.
              Davidfi1
              Welcome back!
              Did you look into solving this in SP3x?
              Could I help?
              Is there going to be an RC2?
              Thank you
              David.
                CPhillips
                I thought I had it fixed but apparently not... I need to setup a bug database so these things dont fall through the cracks.
                  Davidfi1
                  Most logical option is to use Google's bug tracking ...
                    Davidfi1
                    Hi Guys
                    This bug is still not fixed at SP3 on my computer.
                    Thank you.
                    David.
                      CPhillips
                      Hi Guys
                      Thank you.
                      David.
                      Unfortunately the fix caused other models to break. I'll take another look at it and see if I can come up with something safe.
                        Davidfi1
                        Excellent πŸ˜„
                        Thank you.
                        Could you also fix the reverse face issue? http://forums.sketchucation.com/viewtopic.php?f=61&t=24201#p206890
                        Hope it is no too complicated.
                          CPhillips
                          Its fixed in next version. I hope it doesn't break anything but it was a bad bug and needed to be fixed.
                            Davidfi1
                            Exelent thank you.
                            Good work.
                            It works like it should πŸ˜„
