    4 Levels of Grouping
    17 Posts 3 Posters 3.4k Views 3 Watching
    • W Offline
      Wacov
      I see what you mean, but maybe you should just make the parts, and keep a 'spare' of each one. That way, you can create the complex group, then explode the groups within it when they're positioned. If you want to move something, delete the parts and copy the spare, then explode it.
        Davidfi1
        I think about solving this issue with a script.
        I could write a script that will
        Go though all the second level groups, and
        If there is another group inside it - explode it,
        And repeat this for all the groups until we only have two levels of groups.
        What do you think?
        Should I return to the "grouped" state after the simulation stops?
        David.
        • W Offline
          Wacov
          I feel like I'm in too deep πŸ˜„ I think it'd be a good idea if the groups returned afterwards, as they don't really matter in the simulation. I really don't know any ruby script, so good luck πŸ˜„
            CPhillips
            Its a bug. And one I didnt know of. Thanks David.
            Not sure what is causing it but I will fix for SP3.
              CPhillips
              Turns out this isn't really about group depth. It happens when a group contains only a single group.
              Group
                Group
                  etc.
              Ill fix it in SP3.
                Davidfi1
                SketchyPhysics3x Jun 27
                This problem is not solved as far as I can tell
                Thank you.
                David.
                  Davidfi1
                  Welcome back!
                  Did you look into solving this in SP3x?
                  Could I help?
                  Is there going to be an RC2?
                  Thank you
                  David.
                    CPhillips
                    I thought I had it fixed but apparently not... I need to setup a bug database so these things dont fall through the cracks.
                      Davidfi1
                      Most logical option is to use Google's bug tracking ...
                        Davidfi1
                        Hi Guys
                        This bug is still not fixed at SP3 on my computer.
                        Thank you.
                        David.
                          CPhillips
                          Hi Guys
                          Thank you.
                          David.
                          Unfortunately the fix caused other models to break. I'll take another look at it and see if I can come up with something safe.
                            Davidfi1
                            Excellent πŸ˜„
                            Thank you.
                            Could you also fix the reverse face issue? http://forums.sketchucation.com/viewtopic.php?f=61&t=24201#p206890
                            Hope it is no too complicated.
                              CPhillips
                              Its fixed in next version. I hope it doesn't break anything but it was a bad bug and needed to be fixed.
                                Davidfi1
                                Exelent thank you.
                                Good work.
                                It works like it should πŸ˜„
