Editing Component Description
How can I edit a Component Description after the component has already been created?
My first step was Window>Components>InModel(little house button)>Rightclick on the image in the collection window> Properties> type in your corrections in the data fields. I thought it worked.
Then I tried to verify with Click on Component in workspace, Window>Entity Info and I filled in the empty data field.
But in order to respond quickly, I did not double check. I don't do this too often.
You know about the right click, Make Unique? -
Select the component in the components browser. Then type in the larger box at the top and hit Enter.You can change the Component Definition Name in the top row or in the Entity Info box.
ahhh thank you thank you... I searched forever....
