    Running SketchUp with command line redirection
    14 Posts 3 Posters 3.1k Views 3 Watching
    • Al HartA Offline
      Al Hart
      @thomthom said:
      Send the client a shortcut they can run?
      I got one on my desktop to start SU in debug mode - and it outputs the txt file on the desktop.
      Can you send me (al.hart @ renderplus.com) the shortcut, or post it here.
      Thanks,
      Al
      Al Hart
      IRender nXt from Render Plus
        It's on my home computer, but it's not a universal shortcut - as it needs to fit the SU version, location (locale and 64/32bit OS differences), but it's just adding a shortcut with the > debug.txt argument.
          @al hart said:
          One thing that makes this tricky is guessing whether the user has a 64-bit machine, Windows 7, etc. The user is in Australia, so I often only get to exchange 1 email per day because of the way our time zones overlap.
          I guess you can make a BAT file that tests for common locations... ? Or pull the location from the registry.
          @al hart said:
          Also, what to you replace '> debug.txt' with to put it on the desktop?
          I don't - that's all I do.
          But if I use CMD and navigate to SU's folder and launch SU then the txt file is created in the SU folder. So it appear to depend on where you started SU from. Or maybe you can control this by using the "Start in" field on the shortcut properties.
          • Al HartA Offline
            Al Hart
            Thanks for your help on this.
            What to you replace '> debug.txt' with to put it on the desktop?
            I guess I was hoping for a way for the client to navigate to the SketchUp folder, and then do something from Windows explorer.
            I just went to explorer, right clicked on SketchUp.exe and selected "Create Shortcut", then clicked on the shortcut and selected properties.
            But I can't figure out where to put the redirection?
            Al Hart
            • Al HartA Offline
              Al Hart
              oops - I edited my previous post while you were responding to it.
              How do you redirect output in a shortcut?
              I tried: "C:\Program Files\Google\Google SketchUp 8" > debug.txt
              and "C:\Program Files\Google\Google SketchUp 8 > debug.txt"
              In the target line, but neither worked.
              Al Hart
                About to head home now - but I noticed that the path you have there points to the SU folder - not the exe itself.
                  mhd
                  Here is what I threw together. Hope it helps.
                  A Batch file to write the debug output to the desktop
                    Turns out, I was using a BAT file...
                    "C:\Program Files (x86)\Google\Google SketchUp 7\Sketchup.exe" > myRubyLog.txt
                    • Al HartA Offline
                      Al Hart
                      My client figured out how to get to the DOS prompt. But I would still love to figure out a good way to do this.
                      I could create a batch file which the user could unzip into the SketchUp folder.
                      Al Hart
                      • Al HartA Offline
                        Al Hart
                        I create an image to a shortcut to the folder, however the proper shortcut still didn't work with either of these targets:
                        "C:\Program Files\Google\Google SketchUp 8\SketchUp.exe" > debug.txt
                        "C:\Program Files\Google\Google SketchUp 8\SketchUp.exe > debug.txt"
                        It turns out you can access the desktop with:
                        \users%USERNAME%\Desktop
                        as in:
                        echo xxx > \users%USERNAME%\Desktop\debug.txt
                        Here is a script which will work for 32 and 64 bit windows:
                        (I thought I would pass along my trick for making .bat files which work for both 32 and 64 bit systems)
                        @echo off
                        rem - goto proper Program Files
                        c;
                        if "%ProgramFiles(x86)%" == "" goto win32
                            set PFILES=%ProgramFiles(x86)%
                            goto process
                        ;win32
                            set PFILES=%ProgramFiles%
                        ;process
                        echo executing "%PFILES%\Google\Google SketchUp 8\SketchUp.exe"
                        "%PFILES%\Google\Google SketchUp 8\SketchUp.exe" > \users\%USERNAME%\Desktop\debug.txt
                        echo load debug.txt in notepad.
                        notepad \users\%USERNAME%\Desktop\debug.txt
                        Unfortunately, when SketchUp produced its bug splat, it had not flushed its output.
                        Al Hart
                        • Al HartA Offline
                          Al Hart
                          I see that Sketchup replaces $stdout with #Sketchup::Console:0x365e1b0
                          It has a write method, but no flush method
                          $stdout.methods - Object.methods
                          ["write"]
                          $stdout.flush
                          Error: #<NoMethodError: undefined method `flush' for #Sketchup::Console:0x365e1b0>
                          Maybe we can get SketchUp to add a flush method to Sketchup::Console ❓
                          Al Hart
                          • Al HartA Offline
                            Al Hart
                            All this work trying to redirect output led me to come up with a ruby script which will redirect output, and flush the output file.
                            See: http://forums.sketchucation.com/viewtopic.php?f=180&t=31160
                            Al Hart
