    UI.messagebox "beep"
    20 Posts 5 Posters 1.3k Views 5 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Is there a way to turn off the "beep", or the yellow triangle. Am I missing something with the use of UI.messagebox "text"?
        That is a user defined sound set from the Control Panel. The sound will depend on the type of messagebox you create.
          honoluludesktop
          OK, Anyone know of a system cmd I can call to turn the sound off/on?
            I'd recommend you do not mess with user's system preferences!
              honoluludesktop
              OK! Thanks.
                Jim
                There are other series of icons for the messagebox. The default series shows when you use the MB_ type constants:
                ["MB_OK", "MB_OKCANCEL", "MB_ABORTRETRYIGNORE", "MB_YESNOCANCEL", "MB_YESNO", "MB_RETRYCANCEL", "MB_MULTILINE"]
                But if add some constant value to these (excluding MB_MULTILINE), you can get a series of messageboxes using different icons. Here are the constants and the icon series you get:
                  honoluludesktop
                  Jim, that looks good. Not in the API?
                    It's there.
                    http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#messagebox
                    But the return value constant isn't. See the comments at the bottom of the page.
                      Jim
                      The API doesn't mention anything about being able to use a certain icon series by adding a values to the MB constants.
                      I wonder if the return values are still the same in this case?
                        Ah, yea I see now what you mean. Yea - these should be mapped. I had been wishing for such control - similar to what I had in VB and C#.
                          What would probably make it easier to map out was to print out the binary value so we can see which bits are turned on.
                            32.to_s(2) 100000 48.to_s(2) 110000 64.to_s(2) 1000000 80.to_s(2) 1010000 272.to_s(2) 100010000
                              honoluludesktop
                              How do I "add some constant value" to the following?
                              UI:messagebox "my text "+variable, MB_OK
                                Use the bitwise And operator to combine flags:
                                Messagebox with Yes/No button and question mark icon:
                                UI.messagebox('Hello World', MB_YESNO | 32)
                                  honoluludesktop
                                  WOW
                                    The Win32 API docs helped:
                                    http://msdn.microsoft.com/en-us/library/ms645505%28VS.85%29.aspx
                                    Stop: 0x00000010 = 16
                                    Question: 0x00000020 = 32
                                    Explaination (Yellow Alert Triangle): 0x00000030 = 48
                                    Information (Blue Info Circle): 0x00000040 = 64
                                      [16,32,48,64,80].each { |i| puts i.to_s(2).rjust(8,'0') } 00010000 00100000 00110000 01000000 01010000
                                      • Dan RathbunD Offline
                                        Dan Rathbun
                                        I went thru this a fee months ago or so:
                                        It's a Win only thing so far as I know, but I'd like to see what happens on the Mac.
                                        Here's a text report of all the integers and the resultant button styles you get. (I believe some of the icons are deprected, specifically the question icon.)
                                        UI_messagebox.txt
                                        I'm not here much anymore.
                                        • RunnerPackR Offline
                                          RunnerPack
                                          That's actually the Or operator... but you knew that πŸ˜‰
                                          Sorry... pedantic mode, off! πŸ˜„
                                          @Dan: I've also always wondered what all the obviously-Win32-API-based things did on the Mac version... I always assumed they just translated stuff to the appropriate Mac system-calls/constants, but it would be nice to know for sure.
                                          You might have noticed... I'm a bit of a ferpectionist.
                                            Doh! 😳 I swear there's a little brain-gnome that intercepts and swaps words before they reach the hands...
