    UI.messagebox "beep"
    20 Posts 5 Posters 1.6k Views 5 Watching
      @honoluludesktop said:
      Jim, that looks good. Not in the API?
      It's there.
      http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#messagebox
      But the return value constant isn't. See the comments at the bottom of the page.
        Jim
        The API doesn't mention anything about being able to use a certain icon series by adding a values to the MB constants.
        I wonder if the return values are still the same in this case?
          Ah, yea I see now what you mean. Yea - these should be mapped. I had been wishing for such control - similar to what I had in VB and C#.
            What would probably make it easier to map out was to print out the binary value so we can see which bits are turned on.
              32.to_s(2) 100000 48.to_s(2) 110000 64.to_s(2) 1000000 80.to_s(2) 1010000 272.to_s(2) 100010000
              • honoluludesktopH Offline
                honoluludesktop
                How do I "add some constant value" to the following?
                UI:messagebox "my text "+variable, MB_OK
                  Use the bitwise And operator to combine flags:
                  Messagebox with Yes/No button and question mark icon:
                  UI.messagebox('Hello World', MB_YESNO | 32)
                    honoluludesktop
                    WOW
                      The Win32 API docs helped:
                      http://msdn.microsoft.com/en-us/library/ms645505%28VS.85%29.aspx
                      Stop: 0x00000010 = 16
                      Question: 0x00000020 = 32
                      Explaination (Yellow Alert Triangle): 0x00000030 = 48
                      Information (Blue Info Circle): 0x00000040 = 64
                        [16,32,48,64,80].each { |i| puts i.to_s(2).rjust(8,'0') } 00010000 00100000 00110000 01000000 01010000
                        • Dan RathbunD Offline
                          Dan Rathbun
                          I went thru this a fee months ago or so:
                          It's a Win only thing so far as I know, but I'd like to see what happens on the Mac.
                          Here's a text report of all the integers and the resultant button styles you get. (I believe some of the icons are deprected, specifically the question icon.)
                          UI_messagebox.txt
                          I'm not here much anymore.
                          • RunnerPackR Offline
                            RunnerPack
                            That's actually the Or operator... but you knew that 😉
                            Sorry... pedantic mode, off! 😄
                            @Dan: I've also always wondered what all the obviously-Win32-API-based things did on the Mac version... I always assumed they just translated stuff to the appropriate Mac system-calls/constants, but it would be nice to know for sure.
                            You might have noticed... I'm a bit of a ferpectionist.
                              Doh! 😳 I swear there's a little brain-gnome that intercepts and swaps words before they reach the hands...
