    WebDialog (Mac) - style.visibility in SU6
    8 Posts 2 Posters 904 Views 2 Watching
    • T
      tomasz
      I have been testing a WebDialog on Mac that uses a visibility of an object
      getElemendById(id).style.visibility='hidden';
      For some reason SU6 fails to set the visibility. SU7 & SU8 are doing just fine.
      Have anyone experienced similar problem? Is there an easy solution?
        I'm guessing you are sending getElemendById(id).style.visibility='hidden'; to execute_script? Then I think there are character escaping issues if I remember correctly - and it might be different from Windows to OSX.
        If this is not sent to execute_script, - then I'm puzzled.
        • T
          tomasz
          I use following function in JS:
          	function ShowObject(id, flag)
          	   var elem=document.getElementById(id);
          	   if(elem)
          	      elem.style.visibility=flag?'visible';'hidden';
          and I send wd.execute_script("ShowObject('something', 0);")
          For some reason in works on MAC in SU7&8, doesn't hide a thing in SU6(also MAC).
          If I understand correctly SU uses Safari in all versions of SU on Mac. Where can the difference come from? I have no clue.
            Yea - if you test on the same machine the webdialog behaviour be the same between SU versions - which makes me think this is a ruby API bug with execute_script.
            From the Lost Manual: http://forums.sketchucation.com/viewtopic.php?f=180&t=23445
            OSX .execute_script and quotes
            There was some issues with .execute_script and quotes in Sketchup prior to 7.0 on OSX. http://forums.sketchucation.com/viewtopic.php?f=180&t=8316#p49259
            Though that suggested an OSX only problem. You are saying it's on Windows as well?
            CPhillips suggested semi-colons could be an issue: http://forums.sketchucation.com/viewtopic.php?f=180&t=8316#p49259
            @cphillips said:
            I tried adding a semicolon to the line above and it made no difference. In fact semicolons seem to cause problems in certain cases on Mac.
            execute_script("somefunc('hello');")
            Calls the javascript func with the string: "hello);" on Mac. But if I leave the semicolon off it seems to work as intended.
              In your ShowObject(id, flag) function, have you inspected the data it receives?
              • T
                tomasz
                Thanks Thomas for help.
                I have checked the JS function and I have found that on SU6 the 'flag' which is either 0 or 1 was not recognized by the following code:
                I decided to send 'visible' or 'hidden' instead of numbers. Now JS works fine.
                I think that JS expected integers and couldn't convert strings comming from SU6?
                  with your original code, did you try a typeof test of the flag? just to see what it came across as?
                  did you try without semi-colon?
                  • T
                    tomasz
                    I am not JS expert, so I didn't even know that 'typeof' exists 😄. Will check the old code.
                    Yep. I didn't help.
