    Texture won't apply to surface
    4 Posts 3 Posters 1.0k Views 3 Watching
      goblynn93
      I am trying to import a series of pictures to apply as textures to the surface of some cubes to simulate an image printed across multiple surfaces and then jumbled up... I am having problems with some of the imports. The images won't apply where I have told them to and they jump to another cube when I try to apply them!! Below is a link to a YouTube screen capture of the problem in action...
      Thanks for any help or ideas!!
        goblynn93
        Sorry, youtube didnt like the first video!
          alpro
          I would make each block a group, then edit that group to import a texture.
          Mike
          • EarthMoverE Offline
            EarthMover
            That's strange. Happens to me as well sometimes, usually when I somehow get two or more faces on top of each other. Try deleting the face and if another remains, then keep deleting until the face disappears and then hit a single undo to assure there is only a single face. If there is only one face per cube, then I would definitely do as Mike said and group them before applying the texture to isolate all the geometry. You could also try running the Cleanup 2.0 script from Thom Thom and this does a good job of eliminating any unseen model issues.
            Content Creator at Skapeup
