Scenes thumbnail generation
How could I kill this new marvellous
feature? I have 2 PC and on one of them this process is starting by default every time I open an existing file. -
This should only happen the first time you open an SU7 file in SU8. It will then save the thumbnails in the fire for the next time you open it.
You can cancel this on a case by case basis as you open files, but not sure if a way to globally disable it.
