    New API doc - typos and questions
    370 Posts 35 Posters 371.9k Views 35 Watching
    • T
      tomasz
      WebDialog.set_full_security=
      The set_full_security= method is used to place the WebDialog into a higher security mode where remote URLs and plugins (such as Flash) are not allowed inside the browser. This defaults to false when a new WebDialog is created.
      This method does not exist. There is set_full_security BUT It doesn't take arguments!! Also I am not sure if it defaults to false on MAC since it doesn't display Flash while under Windows it does.
      • Dan RathbunD
        Dan Rathbun
        Also the API code example has nothing to do with this method.
        I'm not here much anymore.
        • Dan RathbunD
          Dan Rathbun
          REPOST: from Mon MAR 08, 2010
          The web page has still not been fixed.
          API - Release Notes webpage error
          http://code.google.com/apis/sketchup/docs/releases.html
          The H2 Heading "What's new in SketchUp 7" is not displayed as a H2 heading.
          The error is caused by a missing '>' (greaterthan character) on the end of the preceeding <P> element closing tag, which is now: '</P'
          ie, snippit from current HTML source (line 378):
          ` %(#804000)[<p class="post"> </p
          <h2>What's new in SketchUp 7</h2>]`
          "What's new in SketchUp 7" should be rendered the same as:
          "What's new in SketchUp 7.0 M1"
          Adding a screenshot:Api_Page_Error.png
          • Dan RathbunD
            Dan Rathbun
            The above error on the API Release Notes webpage no longer applies since the release of Sketchup v8.0 ...
            ... because all mention of Maintainance Releases have been scrubbed from the page, including the fixes, functionality and new methods that were introduced by the MR.
            Example (see above,) Sketchup 7.0MR1 added the get_glued_instances instance method to the Sketchup::Face class, but now readers (especially those new to using the SUAPI,) will not know this by looking at this page. They'd need to notice the version on the right, of the method defintion, on the Face class page. [ie: SketchUp 7.0.10247 (M1)+]
            Did anyone save an offline archive of the API Release Notes Page ?? ( Can you attach copy to this thread if so, please. )
              sigh ... I only hope this is because of some restructure of the API site. Better poke a Googler just in case to make sure that info will be available somewhere.
              • Dan RathbunD
                Dan Rathbun
                @thomthom said:
                ... just in case to make sure that info will be available somewhere.
                Isn't there an web archive kept by Google somewhere.. built by bots ??
                • Dan RathbunD
                  Dan Rathbun
                  I also. I'd like to see the page remade like the SU Application Release Notes page, with expanding sections for each release.
                  • Dan RathbunD
                    Dan Rathbun
                    Yes, found it (Google caches their own pages): Release Notes - Google SketchUp Ruby API - v7
                    Not knowing when this cached page will be replaced (possibly the 1st of next month,) here's an offline snapshot:
                    Release Notes - Google SketchUp Ruby API - v7.zip
                    • snicoloS
                      snicolo
                      Guys, thanks for the heads up, you can blame this one on ScottL 🤣 but also he was the one that corrected it, so I guess he is even.
                      Should be fixed shortly.
                      Simone.
                      Simone Nicolo
                      QA Manager
                      http://www.sketchup.com
                        Just saw the updates. 😄
                        Scott even sneaked in a UTM class - which apparently has been there since SU6??
                        • T
                          tomot
                          WOW! no replies for almost a year! Things must really have improved on the SketchUp API side of things .......just kidding!
                          I noticed Google is buying Motorola or 12.5 Billion today http://www.telegraph.co.uk/technology/google/8702132/Google-buys-Motorola-Mobility-in-12.5bn-deal.html
                          Looks like they ran out of money once again, still can't afford to hire someone to get rid of the typos in the API. 😞 😞 😞
                          my plugins
                          tomot
                          • scottliningerS
                            scottlininger
                            Hey Tomot,
                            I'm still listening. 😄
                            We have been making incremental fixes now and then. I'll take this ping as a useful reminder to check the thread for things we still need to do...
                            • Scott Lininger
                              SketchUp Software Engineer
                              Have you visited the Ruby API Docs?
                              What would your preferred channel for API documentation issues be? This thread or the comment pages on the API pages?
                              • scottliningerS
                                scottlininger
                                Reporting issues via the code.google.com comments tool (which you can find at the bottom of every documentation page) is better, because it warns other users right on the page.
                                • Scott Lininger
                                • Dan RathbunD
                                  Dan Rathbun
                                  Yea.. but the formatting sucks!
                                  • scottliningerS
                                    scottlininger
                                    ...of course if you prefer to post nicely formatted stuff to this thread, that's cool, too! 😄
                                    • Scott Lininger
                                      And there is some other wee issues, it quickly wraps the comments into pages, after 10 pages. And it's not always obvious.
                                      The biggest problem is if you have your browser set to prefer a language over English, then you'll be presented with an empty comment page. (I think the comments are all gone.) Every time I have to install a new system, or use another computer here in Norway, and the preferred language is set to Norwegian I cannot see any of the comments.
                                      I have to rearrange the preferred languages to English before I get the comments because the API doc pages forcefully redirect me to a so-called localised version for my language, even though everything is still in English.
                                      So I can imagine there's many people not aware of the comments at the bottom of the API pages.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        It would be better to have INLINE (expandable) comment block beneath each method. I know you guys can do this because you did it on the Release notes pages.
                                        Also expandable sample code block under each method.
                                        Basically it needs to be more like a wiki page. Jim experimented a bit with this on his code site page.
                                        • Dan RathbunD
                                          Dan Rathbun
                                          HOW! ??
                                          I don't think it takes markup... or does it?
                                          If so. What kind? git markup? bbCode? what?
                                          • Dan RathbunD
                                            Dan Rathbun
                                            @Scott.. on the subject of the API... see this thread:
                                            http://groups.google.com/group/sketchupruby/browse_thread/thread/112f655ea6067034/2c575f2d2113a894#2c575f2d2113a894
                                            Wouldn't it be better to have a DC playsound() click function appended to the the DC class?
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 16 / 19
