    Update a WebDialog
    8 Posts 5 Posters 951 Views 5 Watching
    • T
      tomasz
      Is there a way to give a WebDialog enought time to let it update. I mean a 'progress bar' scenario when ruby is doing something and the WD needs to be updated. As far as I know WDs sit on the same thread as Ruby ... I guess it will be hard to force the update.
        I think a few people has tried this - without much luck.
        • T
          tomasz
          So we should file a feature request to have web_dialog.refresh method added.
          • Dan RathbunD
            Dan Rathbun
            Did you try to use Js to refresh the html ??
            PC MSIE [window.location.reload()](http://msdn.microsoft.com/en-us/library/ms536691(v)
            reload from browser cache:
            dlg.execute_script("window.location.reload(false)")
            reload from file:
            dlg.execute_script("window.location.reload(true)")
            The MSDN page says, "Standards Information: There is no public standard that applies to this method."
            So this may be a MSIE only method.
            I do NOT know if it will work on Mac Safari.
            See also:
            [window.location.assign](http://msdn.microsoft.com/en-us/library/ms536342(v)
            [window.location.replace](http://msdn.microsoft.com/en-us/library/ms536712(v)
            I'm not here much anymore.
              That'd just require even more cycles - and it'd cancel out any HTML changes made by JS since it was first loaded.
              The problem is that the webdialog is not allowed any CPU time to update it's UI until after the Ruby loop that's processing is done.
              • Dan RathbunD
                Dan Rathbun
                Well I didn't go into detail.. but you would need to pass anything (vars) that you want to save over to the Ruby side... the page init Js function would request the values again from the Ruby side, same as it did on the initial load, for the default values.
                So they don't run in a new process huh ? But the Ruby loop, could have embedded execute_script calls to periodically give the WD cycles ??
                • N
                  niccah
                  Hey guys!
                  I have to pick up this topic again!
                  My problem: I have a WebDialog to create "Tools" - when a user created a new Tool, one has to update the webdialog.
                  In my case, it looks like this:
                  html = " .... "
                  	dlg = UI;;WebDialog.new("Model2GCode - Tools", true, "Model2GCode - Tools", 800, 300, 50, 50, true);
                  	dlg.set_html html
                  	dlg.show
                  	dlg.add_action_callback("saveNewTool") {
                  Is there a possibility to close the WbDialog, "jump" to the start of the script and open it again? I tried a lot, but I didn't get a running solution.
                  Thanks for all your help!
                    Diggsey
                    Your first problem is very easy to solve, just make sure that your ruby script executes asynchronously.
                    I use this function in a couple of my scripts instead of the outer-most loop:
                    	def asyncLoop(range, &proc)
                    		from = range.min
                    		to = range.max
                    		iteration = lambda do |index|
                    			last = (index > to)
                    			proc.call(index, last)
                    			if !last then
                    				UI.start_timer(0.02, false) { iteration.call(index.succ) }
                    		iteration.call(from)
                    		return nil
                    You can use it like this:
                    		asyncLoop(0...16) do |i, last|
                    			if (!last) then
                    				# Perform ith iteration
                    			else
                    				# Put code to be run after this operation here instead of outside the loop
                    		# Code here will run immediately, so leave it empty
