    The best way to make roads that bend and go up or down?
    17 Posts 10 Posters 14.1k Views 10 Watching
    • pietervP
      pieterv
      Hey Rclub24,
      I have had a look at the 1001bits userguide and I think "Extrude along sloping curved path" is pretty similar to Shape Bender and Follow me and keep. Thanks for the advice anyway!
      This is my website:
      Citypixels - 3d Visualisatie Architectuur
      • pietervP
        pieterv
        Hey Box,
        I am trying the Bezierspline tool and it looks very promising. I will try to post some examples when I'm a bit more advanced.
        Thanks a lot!!
        This is my website:
          Jim57
          Another way that NURBS curves are better for defining the path of the road is you can pull the handles to make them more parabolic. My understanding is that if roads are built using circular arcs, they are hard to drive. You have to pull the wheel from straight to the proper radius at an instant, instead of a smooth transition over (a brief) time.
          Just a design consideration, it says nothing for modeling.
          Best,
          Jim
          • pietervP
            pieterv
            Hey Jim,
            Just to be clear, by NURBS you mean tools like bezierspline?
            This is my website:
              danbig
              Another thought on a workaround:
              If you can get the lines you want in illustrator, why not export to DWG from there and import into sketchup for a starting point?
              • pietervP
                pieterv
                Hi everyone again!
                After some testing I have figured out what the best way is for me to make roads that bend an go up or down at the same time.
                I mainly use two plugins:
                Fredo's BezierSpline plugin: (Of which I only use the Uniform B-Spline tool because of the smooth results for this purpose.)
                http://forums.sketchucation.com/viewtopic.php?f=323&t=13563
                and Wikii's Follow Me and Keep plugin: (to make a road out of the curve)
                http://forums.sketchucation.com/viewtopic.php?t=16465
                This way I was able to make the following interchange:
                http://users.skynet.be/fb517223/interchange/mega-probeersel-140.jpg
                I think the main drawback for the moment is that you have to devide the curves you make with BezierSpline into really a lot of sides until they get smooth. I can be wrong, but it also appears to me that the sides are not equal destributed along the curve.
                @Dabbig:
                Thanks, that might be usefull too one day!
                This is my website:
                • Chris FullmerC
                  That is a nice interchange!
                  • W
                    wyatt
                    Cool. How long did that take once you figured out the right plugins to use?
                    • pietervP
                      pieterv
                      That's hard to say in fact, because I didn't work continiously at it. Let's say I worked a couple of hours every day on it for about four or five days. I find it hard to make an estimation though.
                      This is my website:
                      • GaieusG
                        Indeed a nice result (from here at least - don't bother yourelf with smaller flaws like segmentation - Su is just this kind of a tool).
                          Remarkable result! πŸ‘
