    Question about VUE
    extensions
    8 Posts 4 Posters 1.1k Views 4 Watching
    • coulteriC Offline
      coulteri
      Hello,
      does anybody know, how to populate vertical face in VUE?
      thanks
      coulteri
        matteo
        What do you mean exactly? What kind of population (trees, stones, buildings, people?)
        The simple workaround to start with an horizontal or sloped surface, populate it and then make it vertical with a simple rotation; this may not meet your expectations, because a vertical village looks a bit odd 😜
        You can set better this variable in the material editor: there is a slider that controls the population in relation to the slope.
        hire me: http://www.nonsolo3d.it/ !
        • coulteriC Offline
          coulteri
          I would like to populate the wall of building with plants. Yes, I tried to do it using the way of rotation. I´m not very familiar with VUE and I thought, there could be a switch, that enable vertical populating. Another problem is to make population on face hidden under another face (glasshouse). I solve this merging more projects together after populating of them.
            matteo
            just two words: Ivy Generator
            An Ivy Generator
            (graphics.uni-konstanz.de)
            My avatar image is made with SketchUp (building shapes), populated with Ivy Generator (over the luminous structure), imported into Vue where I added the tree and rendered the whole scene.
            You can easily replace the ivy leaf texture and create different vertical green walls.
            • coulteriC Offline
              coulteri
              Thanksa lot! I will try it.
                bravoddb
                Have you tryed airbrush? with the plants you want?
                • coulteriC Offline
                  coulteri
                  No, I haven´t. ... What is it?
                    karmoh
                    Since version 7 this has been possible by using the slider "Direction from surface" in the ecosystem painter. If set at "perpendicular" you can populate up-side down if you want to.
